FCP X - Pixels Missing on Some Transitions at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old October 12th, 2011, 09:59 AM   #1
The curious picture shrinking bug in FCPX
FYI...FCP X Bug reported by a few people. See Link
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old October 12th, 2011, 03:51 PM   #2
Re: FCP X - Pixels Missing on Some Transitions
This may not be an FCPX bug but an error by the author of those transitions in Motion. The example given here is the Squares transition which I am not familiar with. It may be constructed by mathematical programming or be an image gradient wipe. If it is indeed a gradient wipe then it's possible that the base image the transition is using to achieve the effect is slightly wrong. If it is a mathematical formula then adjusting for pixel dimensions may not have been programmed in the effect.
Old October 13th, 2011, 08:20 AM   #3
William,
From I can tell it is a bug because the problem can be created with some built-in transitions inside FCP X.
From the article: "It is particularly noticeable as the outgoing video stays behind the incoming video until the end of the transition. That results in an edge and the incoming video popping back to its original size.
We thought it was an error in some of the coordinates and maths in the custom transition, not so as you can reproduce the problem with one of Apple's built in effects."
It is somewhat common to find these type of program bugs in NLE's from time to time. That is why it is important to report them to Apple so they can address them.
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
