New version of FCPX available at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old September 20th, 2011, 11:25 AM   #1
I've just seen this - may be old news to some of you, but ...
Apple releases major update to Final Cut Pro X, release demo version
Available at the Mac App Store now
Nick Gordon is offline   Reply With Quote
Old September 20th, 2011, 11:59 AM   #2
MPS Digital Studios
Re: New version of FCPX available
Apple called me to go over the updates, and they also went on the record that multicam and broadcast monitoring support will be available next year (2012). They also told me they are listening to us, and they care about the professional video editor.
Here are details from the call:
Apple Calls With Details On Final Cut Pro X 10.0.1 Update: XML, XSAN, Video and Audio Stem Exports Via Roles, and More | heath mcknight dot com
Heath
My Final Cut Pro X blog
Old September 20th, 2011, 12:11 PM   #3
To little to late. I installed Adobe CS5.5 Production Premium on my Mac Pro today.
Old September 20th, 2011, 12:12 PM   #4
MPS Digital Studios
The 30-day trial is a great way to try it out and see if it's for you.
Heath
Old September 20th, 2011, 12:19 PM   #5
Just to confirm; is this an update for existing FCPX owners (can it be updated from the program, or is this a demo of a new version)?
Simon Wood is offline   Reply With Quote
Old September 20th, 2011, 12:20 PM   #6
MPS Digital Studios
Hey Simon,
You can download the FCP X 10.0.1, Motion 5.0.1 and Compressor 4.0.1 updates from the Mac App Store's update tab, if you bought the first versions. The demo is the latest version, in case someone would like to try it before they buy it.
Heath
Old September 20th, 2011, 03:41 PM   #7
I don't want to risk installing the trial on my FCP 7 system. I read somewhere here on dvinfo that FCP-X doesn't have support for keyframes in the color corrector filter. I don't see it in your blog post. Did they add that support?
Old September 20th, 2011, 03:43 PM   #8
MPS Digital Studios
I'll ask them as a follow-up. Here's some advice on installing FCP X on your system with FCP 7:
http://support.apple.com/kb/HT4722
I have both running on my Mac mini with 8GB of RAM, without partitioning the drive. You have to launch Motion 4 first, then you can open the new apps.
Heath
Old September 20th, 2011, 06:30 PM   #9
Still no way to import FCP 7 projects.
Bob Willis is offline   Reply With Quote
Old September 20th, 2011, 08:08 PM   #10
Heath
Any problems running this on your mini? Just down loaded the demo on my 2010 mini w/8gb ram, 2.66 processor. Do you need to boot into 64 bit mode to run it?
Randy Painter is offline   Reply With Quote
Old September 20th, 2011, 08:11 PM   #11
MPS Digital Studios
I have the entry model 2011 mini and it runs perfect. When I had 2GB of RAM, forget it -- I got stuttering video, the colored volley ball of doom, etc. I am reviewing an upgrade option from OWC for 16GB of RAM and an SSD. WOW! What a difference it makes.
Heath
Old September 20th, 2011, 11:17 PM   #12
I upgraded FCPX tonight and immediately tried to import an XML file that I had exported out of FCP7.
No such luck...
I read on some blog that this was one of the new features. What gives? Did a blogger get it wrong? That never happens!!! :)
Daniel Weber
Daniel Weber is offline   Reply With Quote
Old September 21st, 2011, 02:13 AM   #13
That's Apple being economical with the truth again. If you read up on various forums you'll see this is a "new flavour" of XML (I'm no coding expert so will leave it to others to explain the nuances). It seems it may allow (eventually) some third party to develop a tool that will allow conversion from legacy XML (that you can export out of FCP6/7) to the new version used by FCPX. Then you'll get back the backwards compatibility that any new professional NLE upgraded should have had built in right from the start [....Let's not go there again!]
Just one word or warning for anyone in mission critical FCP6/7 projects that they need to read up before trying this FCPX trial. I've read on various forums that installing FCPX can cause many problems with a legacy FCS suites functionality that's on the sam Mac. Again, others in the thick of it can, I'm sure, elaborate the exact details of what could happen and best practice to prevent it. I do think its good that Apple have enabled people to try it out though - just be careful!
Old September 21st, 2011, 04:28 AM   #14
Here's the technical side of XML and FCPX:
A quick note on the Final Cut Pro X XML format - Digital Rebellion Blog
This reminds me of way back to FCP2 when all sorts of functionality was being developed as third party items for the program and after a while Apple either came up with their own method or bought the program outright and integrated it into FCP. Cinema Tools is an example of this. Another example was serial deck control which didn't make it's way in until FCP3 if I remember.
Old September 21st, 2011, 09:01 AM   #15
MPS Digital Studios
For now, you can buy CatDV and import an XML from FCP 7, and it apparently will export an XML for FCP X.
What is CatDV?
heath
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
