How to conform 60p>24p in FCPX at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old July 3rd, 2011, 02:19 PM   #1
One of the coolest things about 60p is the ability to get a 2.5X slow motion effect without frame blending or optical flow. With the old Final Cut Studio, we used Cinema Tools to re-conform the 60p footage over a 24p timeframe (thanks to Tim Dashwood). How do we do this without Cinema Tools?
It's actually quite easy. You have to setup your timeline for 24p (23.976) first, then drop your 60p clips in the timeline. Select the clip and choose "conform" from the retiming menu. DONE.
I have a video showing how here along with a sample:
60p to 24p in FCPX | davechapfilms
David Chapman
www.davechapfilms.com
David Chapman is offline   Reply With Quote
Old July 4th, 2011, 12:45 PM   #2
Re: How to conform 60p>24p in FCPX
The 180º rule for 24fps maintains a shutter of 1/48 (24 x 2 = 48). For DSLR cameras, you get as close as possible giving a shutter speed of 1/50.
When shooting 60fps, you still want as close as possible to 1/120 (1/125 for DSLRs).
I updated my previous post with a new clip:
Yes, there is a slight grade done in FCPX.
David Chapman
Old July 4th, 2011, 01:26 PM   #3
Very nice, thanks for the tip!
I still have Cinema Tools of course, but it's nice being able to do it in FCP.
Is the conform in FCP less strict about what files it will conform also, maybe? Cinema Tools is very fond of giving time compression errors. :D
Henrik Reach is offline   Reply With Quote
Old July 4th, 2011, 02:57 PM   #4
Quick question (sorry for going OT) - is it possible to conform 25fps to 24fps in FCPX? I will be shooting footage in PAL but will need to deliver some DVD's in the USA. Thanks.
Simon Wood is offline   Reply With Quote
Old July 5th, 2011, 01:49 PM   #5
I'm not sure. So far, FCPX hasn't given any errors. Basically, it just does the math for the speed it should be. In FCP6 and 7, changing the speed also introduced frame blending since it was actually doing a retime instead of a conform.
You know, the conform will make the video longer, and then throwing any audio out of sync (or just stretching it out). If you drop it into the timeline, or use Compressor to set a new frame rate, it would workout better than a conform. But, there could be other workflows people use that could chime in for this?
David Chapman
Old July 5th, 2011, 07:39 PM   #6
Cinema Tools would only conform clips that used an "all I-frame codec" so codecs like Mpeg2 (XDCAM), H264 (AVCHD), etc. had to be transcoded to ProRes422 first. I wonder if this new method in FCP X works on any clip regardless of codec? From David's video it looks like H264 works just fine.
Tim Dashwood
Old July 6th, 2011, 05:43 PM   #7
MPS Digital Studios
I was converting 25p to 23.98 fps a few years back with Cinema Tools, so I'm curious. I know the "rule" of slowing down your footage by 4%, but I'm not sure how FCP X will handle the audio. I know Cinema Tools did it better than FCP 5 or 6 (never tried it in 7), with the audio only dropping in pitch, not sounding like slo-mo.
heath
My Final Cut Pro X blog
Old July 17th, 2011, 08:41 AM   #8
Someone asked how you set the conform rate. The project settings have to contain the frame rate you are targeting for the conversion (in my case, 23.967) and the box needs to be unchecked to match the frame rate to the first clip added to the storyline.
David Chapman
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
