proxy workflow? at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old July 2nd, 2011, 11:35 PM   #1
proxy workflow?
Hi.
got FCP X and starting some projects on it. I've never used proxy before because always had enough HD space.
I'm wondering if anyone can share what is a tipical workflow with proxy in FCP X.
1- I see that you have the option in preference to use proxy or original/transcoded
2- seems weird that it makes applies to every event, it'll make more sense to me if i could have individual events/projects selected as proxy or original
3- seems you can't have mixed proxy and proRes in one event/project
4- so if I want to import files like..a a film burn clip, or any other type of file..does it have to be proxy too?
I will go to proRes but I need to safe on space so I thought I try this..
any help will be appreciated..
thank you
FCPS2, G5 Dual core 2.0 GHz, 2.5 Ram, Dell 2408, M-audio DX4, DVX 100A, Sachtler DV6, Manfrotto 561B, Zoom H-4, RE-50, AT890 shotgun, steadicam Merlin,
Osmany Tellez is offline   Reply With Quote
Old July 2nd, 2011, 11:50 PM   #2
Re: proxy workflow?
When you import from camera (or hdd archive) you have the option to create proxy files for that event. So, in that case it does prompt on a per-project basis.
Ryan Douthit is offline   Reply With Quote
Old July 3rd, 2011, 08:02 AM   #3
Re: proxy workflow?
thanks Ryan... but i know that thou...
Old July 3rd, 2011, 01:56 PM   #4
Re: proxy workflow?
...........anyone?
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
