No widescreen matte generator? Any workarounds? at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old June 24th, 2011, 02:40 PM   #1
Where I would usually use the Widescreen Matte generator in FCP 7 to apply a 2.35:1 matte and offset my clips accordingly I can't seem to find that generator or its equivelent in FCP X. Has anyone found a work around for this? The key for me is being able to easily offset my clips as needed.
Matthew Portwood - http://www.matthewportwoodfilms.com
--Sony A7s, Premiere Pro CC, iMac i5
Matt Portwood is offline   Reply With Quote
Old June 24th, 2011, 03:41 PM   #2
Re: No widescreen matte generator? Any workarounds?
Pick a clip on the timeline, go to effects and find letterbox. You can choose "stylize" to reduce the number of filters. Drag the effect onto your clip. The ratio choices are available in the inspector window.
Old June 24th, 2011, 06:19 PM   #3
I find it interesting that they have implemented this as an effect rather than a generator. As a generator it was just a matte which you could offset the image underneath. As an effect unless I am missing something there is no way to fine tune your framing for each clip.
Old June 24th, 2011, 07:53 PM   #4
I can probably whip something up pretty quickly for you. However, in FCP3-7 this was a filter, not a generator, that could be applied to each clip so that you could shift the underlying image up and down.
Tim Dashwood
Old June 24th, 2011, 08:14 PM   #5
I made an effect template for you that works exactly like the Widescreen filter in previous versions of FCP with Offset, Border Size, Border Color and Opacity.
Just unzip it and drop into your ...Movies/Motion Templates/Effects folder and it will show up in effects when you search for "widescreen."
I've attached a screen grab as well so you can see how it should look.
Tim Dashwood
Old June 24th, 2011, 11:38 PM   #6
Tim you are a wizard! Thanks so much for that it works great! I don't know how the hell you did it, but big props to ya!
Old June 25th, 2011, 12:52 AM   #7
For everything that went "missing" in FCP X, there was actually a lot of cross-compatibility added to Motion 5 so it is fairly easy to put together basic geometric effects for FCP X or even tunnel FxPlug plugins back into FCP X. That's basically what I did since the Widescreen filter was FxPlug and still existed in Motion 5.
This same technique can be used to port over lots of the old FxPlug plugins. Just let me know what seems to be missing and I can do it quickly.
I've spent the last three days doing the same thing for all my own plugins.
Tim Dashwood
Old June 25th, 2011, 11:40 AM   #8
Then it's time to finally learn Motion for me.
Old June 29th, 2011, 04:02 AM   #9
Thank you, Thank you very much Tim, for you matte generator.
2 questions:
Which offset must need to have a matte : 1: 2,40 ?
And how to put the matte on all the clips (without compound clips) ?
Greetings from South of France/Provence
Pierre Alt is offline   Reply With Quote
Old November 4th, 2011, 02:09 PM   #10
Tim - what you have created may solve my problem too - THANKS for this - I cannot seem to find the path "Movies/Motion Templates/Effects folder" to drag your widescreen folder into - I am on a mac pro tower - am i missing something?
Pre Planning Prevents Poor Production.
Jonathan Lawrence is offline   Reply With Quote
Old November 5th, 2011, 12:57 AM   #11
Is that a path for Motion? I may have misunderstood -- I thought it was fix for Premiere CS 5.5 !
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
