XL H1s recoording options? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions
DTE (Direct To Edit) systems which bypass the video capture process.
Old August 1st, 2018, 01:56 PM   #1
I'm several years behind on this topic and wonder what might currently be the best solution/s for recording with an XL H1s without having to convert/transfer from Mini HDV tape?
Chris Weinmann is offline   Reply With Quote
Old August 1st, 2018, 11:08 PM   #2
Re: XL H1s recoording options?
The XL-H1 has an HD-SDI output, so any number of external recorders would work. From the cheap Blackmagic Video Assist up to the Video Devices Pix E7. Basically anything that can take an HD-SDI input can record from your camera.
Edward Carlson is offline   Reply With Quote
Old August 2nd, 2018, 01:04 AM   #3
I used a NanoFlash recorder, now a bit out of date, which recorded quite decent , if large, 1080 25p files.
I triggered the Nano "direct" via a separate "Hawkswood" trigger cable. That way no need to trouble the XLH1 tape mechanism.
Ron
Ronald Jackson is offline   Reply With Quote
Old August 4th, 2018, 08:48 AM   #4
Thanks, Ron and Edward.
I was looking at the Nano Flash X years ago but dropped the subject and have become interested again.
My impression is that few are still wrestling with tape as I am.
Sounds like, look at various external recorders, compare reviews and take it from there.
Old August 4th, 2018, 07:21 PM   #5
Chris, I have an Atomos Samurai Blade listed on the classifieds page. It would be a good fit for your XLH1s.
-Steve
www.CinemActionFilms.com
Steven Reid is offline   Reply With Quote
Old August 7th, 2018, 05:50 PM   #6
Steve,
Thanks, and, I haven't committed to the camera yet but if/when I do and your Blade is still available I'll be in touch. -Chris
Old August 15th, 2018, 01:28 AM   #7
I'm using Blackmagic video assist on three xlh1's via sdi and am very happy with the result.
Owen
Owen Dawe is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions
