timecode burn in? URGENT!! please hellp... at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
Old May 25th, 2007, 01:40 PM   #1
I am using an xl2 with a laptop connected and DV rack running...i am recording to tape and the laptop....this is what I need to do...
I have the files on my computer from dv rack which have the timecode of the tape so if I ever loose those files I can recapture with easy....my client needs me to export the uncompressed dv footage to quicktime and make sure the timecode stays the same as the tape...
this is because they wish for me to upload the quicktime mov files to the net so they can start editing while I mail them the tape and uncompressed footage....
I need to make sure that the quicktime files have the same timecode as the tape and uncompressed footage so that when they go to capture the high quality footage or use the uncompressed video files
...the timecode is not different than the quicktime mov files and everything from their edit with the quicktime files are the same and on snyc..
please help...i need this by today and I apologize for the messege for I am typing this on my cell phone.
thanks, mike
Michael Sweeney is offline   Reply With Quote
Old May 26th, 2007, 06:16 AM   #2
First off, your footage is not uncompressed.
The Canon XL2 records DV at a 5:1 compression ratio.
If you were feeding a firewire signal fron the XL2 while recording with DV Rack, then the files you recorded to disc also would be DV with a 5:1 compression ratio.
Second, I hope both you and your client have a very very fast internet connection.
As long as you setup DV Rack properly, you should be OK with the timecode issue.
Good Luck!
Old June 5th, 2007, 08:07 AM   #3
sounds you should change to XDCAM - and send them the proxies via internet...
ULI
Uli Mors is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
