HDVSplit: great for tapeless ! at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
Old June 12th, 2006, 06:24 PM   #1
Using my HDR-FX1, connected by Firewire to a portable HP ze2020 Pentium M 1.5Ghz and linked to a USB 2.0 Maxtor 7200rpm 200Gig Hard Drive, I decided to test the "live" capture ability of HDVSplit version 0.75. I plugged the camcorder and started recording (without preview: my portable can't handle it very well) and was able to capture 12 minutes of HDV direct-to-disk without dropping a frame.
I'm sure it can capture more than that, but I rarely shoot takes that are longer than 5 minutes so, for me, it works pretty well and, being a free program, is better than DVRack at capturing using my HP. DVRack kept crashing every time I moved the window.
Of course, DVRack has a lot more utilities, but for cheap reliable captures, I'll stick to HDVSplit.
Jocelyn Deguise is offline   Reply With Quote
Old June 28th, 2006, 05:07 PM   #2
thanks for the report - i didnt know it can capture live..
i'll try it with my HD100...
http://www.wizedot.com
Ram Ganesh is offline   Reply With Quote
Old July 18th, 2006, 06:08 AM   #3
No luck with JVC GYHD101E
I try all setting on firewire and none working to capture live
i read some portable HD capture on like FS or citidisk, JVC 's own HD recorder
but seems no way to make it work as Sony.
i try both HDVsplit and CapDvhs.
bad luck, now my last hope ( may be not the last!)is Black magic HD extreme
it's 4:2:2 and 10bits , perhaps makes better than HDV in mpeg2 format.
i can use DV tape but rather as backup than sole recording source. the play back is not so well, it drop frames often.
any Guru has a solution? PC is dirt cheap and i use a celeron 800 to capture live before in sony HC1. very good result, indeed
JY
John Yamamoto is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
