VLC For Capture And Conversion To Progressive DV?
I’ve been using VLC Player to watch live streaming firewire output from my DV camera to my notebook. What I love about this is the beautifully smooth way VLC deinterlaces on the fly.
What I’m wondering is, since it can do this so well in real time, is there a way for it to write those files to my hard drive as progressive scan DV? I’ve looked around a bit and it SEEMS like it can do it, but the interface has me stumped. The reason I’d like to do this is for converting my DV file to (fake) HD with Red Giants Instant HD program. The problem is, Instant HD requires progressive input, and my Canon Optura Xi is interlaced. If VLC cannot do the capture/convert to progressive, is there some other solution? I am just using the firewire input on my P4 notebook. Thanks, and sorry if this has been covered here before. Kevin PS> I also have Vegas Video 6 |
I'm not getting any replies around here either, seriously. I'm sure there is some information linked on the web somewhere about this stuff, but I don't want to spend six hours googling it.
Hey Wayne. It seems like a qood question. I'll let you know if I find out anything.
Kevin |
#4 | |
Basically you'll read in your DV file, separate fields (alternate lines), the smart deinterlacer will then read this and generate progressive video at double the frame rate (this is what VLC does), and then you can resize/interpolate to get higher resolutions, using some of the better algorithms, such Lanczos. Also check out http://www.100fps.com/ for detailed info on how to go about it. |
#5 |
Thanks Gian,
What I still don't understand is; can you capture the de-interlaced streams back into your hard drive and re-use them later? |
#6 |
After de-interlacing a video clip, all moving objects would be blurred.
#7 |
#8 |
