Can I Record In DV Cam Mode Direct-To-Disk? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
Old May 5th, 2005, 12:21 PM   #1
Or is that just a tape speed feature and does not come into play going directly to hard drive?
DV Cam is 8 bit with a 5 to 1 compression ratio and 4:2:0 sampling rate. Is this what goes onto the hard drive if I switch to DV Cam or must I record only to tapeto utilize DV CAM mode?
Interesting, if true. And interesting anyway.
Hugh DiMauro is offline   Reply With Quote
Old May 5th, 2005, 01:14 PM   #2
Barry Wan Kenobi
DVCAM is bitstream identical to DV. What you get on the hard disk will be identical, whether it's DV or DVCAM.
The difference between DV and DVCAM is not in the data, but in the way it's written to tape. Since the hard disk isn't tape, those differences disappear, and you could write DV or DVCAM to the hard disk equally -- they'll be identical.
Old May 5th, 2005, 01:34 PM   #3
Thanks Barry!
That's why you be "da man!"
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
