Field Audio Mixer with 4 inputs and 4 outputs
Hi, I was wondering, if there is a mixer for field, but with 4 inputs and it is important to have 4 outputs.
Technically speaking this is what I want to do. I want to have 4 sources of audio channels, recorded to RED One camera, but as you might know, to do balance of the sound, to avoid peaking and other problems, you have to go to the camera menu to change the levels. So, I want to design a system, where audio sources go thru a mixer, and each channel is leveled before sending to RED. Maybe there is a better solution you can recommend, as I have described what I want to do. I would appreciate your timely input. Phantom power is nessesary of course. And as anybody and as always affordable but good quality :) Thanks in advance Last edited by Levan Bakhia; June 24th, 2009 at 04:17 PM. Reason: Upss sorry wrong place to post this. |
oh, and if there is a single unit, 4 channel transmitter/receiver, that would remove cables from my solution. Let me know :)
Dear Levan,
Have you considered the Sound Devices 442 Mixer? It has four inputs and four isolated outputs. 442 Field Mixer | Sound Devices, LLC
Dan Keaton Augusta Georgia |
