#16 | |
EDIT: 64 GB SD cards will be out this Spring. Two 64 GB SD cards should give you close to 15 minutes of 4:2:2 uncompressed HD video. Last edited by Mark Job; February 9th, 2009 at 11:03 PM. |
#17 | |
For grins, I just did a render of some uncompressed material I had laying around. 1 minute of uncompressed 1080p was 44.5GB. That same render to lossless Jpeg2000 was 629MB with a data rate of about 90Mbps. To me, wavelet compression is going to be the answer. It's good enough for feature film, and it's good enough for VFX. Why kill yourself over uncompressed HD? No one needs it.
DVX100, PMW-EX1, Canon 550D, FigRig, Dell Octocore, Avid MC4/5, MB Looks, RedCineX, Matrox MX02 mini, GTech RAID, Edirol R-4, Senn. G2 Evo, Countryman, Moles and Lowels. |
#18 | |
#19 | |
Mark,
Clearly my opinions are just that, but what exactly is your target market for this unit? I own a camera with an SDI port and would like to have high quality external recording. That puts me as a potential customer (depending on budgets) for your unit, the Nano-Flash, and the XDR. The Wafian units are just too expeinsive and I could never justify them. So let's get back to the meat of the matter. How many users shooting on consumer based cams are going to be doing film-outs? And of those, how many are going to need to send VFX plates from a handycam to a VFX studio? Even if you were pulling raw sensor data, the BEST you could hope for off one of these cameras is a 2/3" sensor's RAW data. Meanwhile, over in RED land, they are taking the RAW sensor data, and using wavelet compression to bring that 4k/3k/2k/1080p image onto REDDrives, or CF cards. And they are doing it at either 224 or 288 Mbps (28MBps or 36 MBps respectively). If the RED team thinks they can get motion picture quality from a wavelet based codec compressing 4K images at 36 MBps, then why on earth do you think you need to approach 100 MBps to encode 1080p? You are unnecessarily complicating the workflow for users who neither need it nor want it. I also think you'd be doing yourself a terrible disservice to limit the unit to one card. For those who want and can afford SDXC, the extended recording capacity will likely be most welcome. For those who cannot afford SDXC, the multiple slots will be necessary to have any decent recording time. Especially, if you press on with the idea of uncompressed HD. I think you could do a good thing here. In some ways, I think Convergent missed the boat in a few areas, especially with respect to the codec. Mpeg has some nice advantages, but I would have preferred an intra-frame codec, and especially a wavelet one. It would have greatly eased media spec issues, added some cachet by being intra-frame, and would have been just as easy to cut due to lower bitrates. Please try to think of the workflow of your potential customers. I'd venture to guess that less than 1% of readers on this board could handle uncompressed HD coming off your unit. And probably the same percentage would have true interest in filmout and VFX. But I'd bet a LOT of folks here would be THRILLED to have an easy cutting intra-frame codec that was visually lossless from uncompressed, at a reasonable price. While I have no love for HDV, I think it's probably prudent to include it for compatibility's sake. In fact, it wouldn't be a bad idea to include a tiered approach to the available recording codecs. 1. DV for legacy recording 2. HDV - low end HD recording with extended record times 3. DNxHD - cross-platform compatible codec that is more standardized than MXF 4. JP2K - Wavelet codec offering truly lossless or visually lossless compression. Of course, finding chip encoders for these could be tricky, and doing it in software is always dicey. But again, look at your potential audience, their needs, and their pocketbook. In this regard, I think Convergent has it about right. Releasing a strong entry at the 5k range for pro shooters, and releasing something in the $3k range for amateur shooters with more modest needs. What we don't have is something in the $1500 range that shoots on SD cards for those looking for a Firestore replacement. Anyway, just my thoughts from the customer side. Quote:
#20 | |
Convergent Design
I don't know if you are aware, but we just released the firmware to support 100 and 160 Mbps I-Frame only recording and playback (4:2:2, full-raster). Yes, this is MPEG2, but it's 100% intra-frame. The choice of a particular CODEC is a balancing act between many factors, including cost, power, quality, size, flexibility, and NLE support. I still think we made an outstanding choice to use the Sony MPEG2 CODEC module in our products. We have excellent NLE support with FCP, Avid, Edius and in the future Premiere. We offer outstanding video quality, especialy at 100Mbps Long-GOP. Just ask Richard Wolenowski, a Viper camera shooter who plans to use the XDR for a couple of upcoming films. Our CODEC is extremely flexible and can operate from 18 Mbps (for proxy) up to 100 Mbps Long-GOP or 160 Mbps I-Frame only. It is also reasonably priced and very low-power (around 3W). It is also small enough that we can build a miniature recorder like the nanoFlash! Best-
Mike Schell Convergent Design |
#21 |
Yes Mike, I am aware of the i-Frame modes on the XDR. And I do think these are a step in the right direction. Part of me just wishes they weren't mpeg2. Not to say they won't LOOK great, just that I think the same quality could have been had a lower data rates and in less storage space with different choices. But I understand when doing things in hardware, choices have to be made, and there probably aren't a lot of wavelet chip compressors out there and Mpeg2 compressors are likely plentiful.
You are right on the codec support front with NLEs. However, I think it's a pretty basic matter to ship a CD with the product that installs a quicktime and/or VFW compatible driver or codec for the support. But that may not help you inside the unit. I've looked at the video samples you guys have posted so far, and will be looking at more. So far it's been very good, but my opinion doesn't mean squat. I still want to see some HD-Stream footage going into the unit, on some narrative or sports shooting, and see how that looks. And how much space we are talking per minute for that look. I am glad to see this market heat up. A lot of people are going to benefit what you guys are doing. I just want to see realistic options coming from them. And frankly uncompressed HD going onto SDHC or even SDXC cards isn't going to be all that helpful to me, or anyone I can think of shooting on sub 10-k cameras. I know Mark is talking about the unit supporting 4:4:4 but how many dual-link of 3g-sdi cameras are out there? And is this really the target market? As soon as you say HDV the dual link guys are going to tune out, and the sub $10k folks are lucky if they even have single SDI ports. In fact, I think only the EX1/EX3 and HPX cams have the capability. Maybe the higher end JVCs do, but I'm not sure. Good luck to all of you guys as far as I am concerned. I certainly wish a realistic option had been available last year when I got my cam, so I could have replaced the firestore.
#22 | |||||||||||||
...I appreciate your feedback Perrone :-) |
#23 | |||||||||
Ok, now I better understand where you see this going. I think it's going to be tough to hit both markets with a single product. Basic rules of marketing (market segmentation) typically dictate product differentiation. You don't sell a Cadillac to a Chevy buyer and vice versa. But maybe you can make it work. A good product at a great price is always welcome! As such, we can probably agree that the "consumer" buyer is going to be most interested in the firewire and HDMI connection to the unit, is likely going to want the 4:2:2 since that's all his NLE will handle, and is going to want a codec that s/he can cut on in Vegas/Liquid/FCP/FCE/ etc. The Indie shooter is going to be interested in 4:2:2 or maybe 4:4:4, will welcome the SDI connection, will welcome an HDMI out for monitoring, and will be interested in wavelet codecs, maybe uncompressed HD (though I still have my doubts), ProResHQ, DNxHD or AvidMXF, and the rest. Quote:
Now, not everyone is going to need 4 hours of time, but when we look at the original market for the Firestore, that is EXACTLY what it offered. It was EXACTLY what I needed, and we bought one. I even upgraded it to HDV so I could use it with the EX1. The Firestore proved to be immensely popular with Panasonic HVX users because of P2 card costs and hugely limited capacity. I think the market is there, I just happen to think it's all higher end market for many of these more expensive products. Folks are not going to pay more for a recorder, than they did for the camera. Unless they are getting paid to do so. It seems that people are willing to pay 1/4 - 1/3 the camera costs for long-form recording solutions if I read the market correctly. Glad to offer it. And again, it's just my opinions as an event shooter and Govt/Corp. shooter. I have no real narrative shooting opinion but you can get those from others here. I was shocked to hear how much footage the Wedding guys were shooting, so long form solutions seem tailor made for them. Especially solid state which is quiet.
#24 |
What should the box material be made of ?
Hi friends. We need your help. Please tell us what you think. What should the box be made of ??? Plastic ? Metal ? Waterproof to 150 fathoms ???? I want the box dimensions to be 4 inches Wide X 4 inches Long X 2 1/2 inches deep. I'm playing here with a piece of Balsa wood to try and get a physical size idea and parking that on the end of my Canon XL H1. I'm editing two shows and drinking my 5th cup of Java and fighting off a high fever at the same time. Perhaps we should add an EMT person to our development team ?
#25 | |
It's called Delrin and it's popular in military applications and in SCUBA (especially cave diving). It's reasonably light, darn near bulletproof, non-metallic, non-magnetic, can be cut on a lathe or with machining tools, can be painted, grooved, sanded, etc. Love the stuff. As for physical size, I'd vote for something like the Firestore FS-4. Plenty of room for connections and cables, you can get a firm grip on it, and you can actually LABEL the connections properly.
#26 | |
#27 | |
The FS-4 is like a brick. But I'm an earthy guy so I like bricks. What I don't care for is piddly electronic things that feel like I am about to break them if I touch them wrong. Selling someone a brick for $2k is a HECK of a lot easier than selling them something that looks like an iPod for $2k! :) Thinking about what you're going to have going on in that box, you're going to need a heat-sink in there since you are probably NOT going to want a fan. You'll need vent holes and air flow. You'll need room for a screen unless you are thinking of trying OLED. I've got some friends doing that technology for other products if you're interested. Is the unit going to have a on-board power supply, or a cable assembly with an inline transformer? Will it have battery capability? If so, you're going to need size for that, and some depth to accomodate it. LiON is clearly the way to go there. Or maybe LiPoly. LED status lights to keep the power requirements down. This could be a fun project, and you could draw real inspiration from a number of sources. I kinda wish I was involved in something like this. I have tons of ideas.
#28 | |||
...You are a part of the project and we welcome your input. We are listening and taking all feedback into review and consideration. Our electrical engineer has also expressed the opinion that he considers there to be great value in exploring all leads. Information is value and it helps us to continue to refine. We do appreciate all feedback. |
#29 |
Project Update For Saturday Feb 14, 2009
Hi friends. Things are truly moving along quite well in our SD card recorder development project. We should have feature set, interface, and IC spec'd out by next week. After this stage is complete comes the horendous FPGA process ! There are three stages minimum to the motherboard design. We think we can now build the first prototype for about 40 % less than we originally thought we could do it for ! Yay ! :-)
#30 |
There are additional things to consider: 'voice of the customer' surveys, ergonomics, field testing (accelerated stress testing, firmware testing, drop testing, wide variety of camcorders, climate extremes), RF interference certification, firmware revision, injection molding/machining, PCB manufacture, distribution, packaging, marketing etc.
