How many GB per minute from 16mm to HDrive? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
Old September 27th, 2007, 03:01 PM   #1
How many GB is it per minute to capture from 16mm film to Hard drive?
Do you think it would be possible to squeeze uncompressed data to a USB flash drive that can be used to carry around? So many questions...but what's the biggest storage size we can get a USB flash drive these days?
Nick Medrano is offline   Reply With Quote
Old September 27th, 2007, 03:32 PM   #2
Well, not sure you can get this much in a little USB thumb sized "drive", but if you get a USB Compact Flash reader (maybe $15 to $30) you can easily get 16GB Compact Flash cards at reasonable prices. I have two of them that I use in my Sound Devices 702 and I transfer the audio to the PC with one of these readers.
Old September 27th, 2007, 03:56 PM   #3
right, but do u think we can squeeze uncompressed HD data onto a usb thumb drive? Probably not enough space on there....
Old September 27th, 2007, 04:02 PM   #4
Define uncompressed HD.
Ar you talking 720p or 1080p. Are we talking _full uncompressed_ 4:4:4 or some visually lossless 4:2:2 footage?
I don't think it will work either way.
Bennis Hahn is offline   Reply With Quote
Old September 27th, 2007, 04:40 PM   #5
I guess the question is "How much uncompressed data"?
Obviously you can get 16GB
I think the data rate is also a big issue. As I recall the Panny P2 cards actually stripe the data to several cards in a RAID configuration to get the sustained data rate high enough.
I'm not sure about the data rate on the new flash cards (PCI-x)
Old September 28th, 2007, 03:47 AM   #6
Uncompressed 10-bit HD at 1080i/30fps/RGB is 249MB/s, one minute is 15GB...
Download the AJA data rate calculator - you will love this tool:
http://www.aja.com/ajashare/AJA_Data...tor_v2.app.tar
Jamie Allan is offline   Reply With Quote
Old September 29th, 2007, 09:26 AM   #7
The reason I was asking about this was because I was wondering if we will soon be able to do "tapeless" transfers from 16mm film to hard drive (Usb stick) in the very near future. It will help save shipping costs and also just be much more convenient. Lots of stock video places are doing hard drive transfers and doing away with tapes...but you gotta either send them a hard drive or buy one of their hard drives. It gets pretty expensive.
Old September 29th, 2007, 11:55 AM   #8
At the memory size required for the job you ask, a simple 2.5" (around 100gig) will cost infinitely less than the same amount in a solid state memory format. simply use a cheap USB box for hardisk.
and it will a lot faster too.
yes , harddisk still rules.....
Old September 29th, 2007, 03:22 PM   #9
I'm using a couple of 160GB 2.5" hard drives for recording in addition to the 16GB flash cards.
The drives are maybe 10X or 12X cheaper thank flash, and the larger external drives are maybe half s expensive as the 2.5"
I don't see the flash memory cards catching up to hard drives in the next few years as the technology to increase hard drive capacity is better known. Now that disk drive have gone to perpendicular recording, the next thing on the horizon appears to be heat assisted recording where a small laser is used to heat the reagion that's about to be magnetized.
The heat lowers the coercivity or in other wods makes it possible to switch the magnetic state with less power, which translates into the ability to write at higher frequency which equates to higher density.
Of course, at elevated temperatures, the medium can revert to its unwritten state easily as well, but since the region cools quickly the magnetic domains will remain stable at the lower temperature.
I think it will be harder to get the flash technology to improve as quickly as the hard drive
Jim Andrada is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
