Recommended RAIDs? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
Old August 3rd, 2007, 10:57 AM   #1
Recommended RAIDs?
I need to do a project with an HDCAM source tape and Vegas. I'll have the HDCAM tape captured to a USB hard drive (and backup) as an uncompressed AVI file. But for editing, I will want to use a RAID. What do you recommend?
BTW, this is 1080i. Multiplying out 1080 x 1920 x 30fps x 8bits x 3colors yields about 1.5 Gbps. No audio needed.
Thanks for your suggestions!
Jon Fairhurst
Old August 9th, 2007, 06:55 AM   #2
RAID-0 is the only way to go. It's the fastest. No backup though, if you lose one of the two drives, they are both worthless.
Jon Omiatek is offline   Reply With Quote
Old August 9th, 2007, 07:52 AM   #3
USB won't be fast enough to capture that uncompressed, you'll need a caldigit HD pro tower raid or similar to get high enough write speeds.
Jamie Allan is offline   Reply With Quote
Old August 9th, 2007, 07:57 AM   #4
PS - 1920x1080 @ 30fps @ 8-bit RGBA = 248.83 MBytes/S = 897.87 GB per hour according to AJA's data rate calculator...
Old August 9th, 2007, 08:37 AM   #5
No way you can get a 2 disk array to sustain a 240+ MB/s stream. You need at least 4 disks minimum in Raid0, depending on the fill rate of your disks. If you go over 50-60% fill rate you may need 6 disks or more.
Old August 9th, 2007, 09:33 AM   #6
Images: 10
I submit that fiber channel raid is the only way to get these data rates in a scalable, rational way.
Bill Ravens is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
