Minimum laptop (Mac) specs to PLAY DVCPROHD? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
Old July 29th, 2007, 09:54 AM   #1
Hi,
i've not enough budget for an F100, so i'm opting for a portable Mac to which i will copy the P2 data from my HVX200. To veryfy the footage, the laptop should be able at least to playback the DVCPRO HD footage.
So is a simple iBook enough to playback a DVCPRO HD footage from internal HD (5400 RPM) or should i use a PowerBook?
Giovanni Speranza is offline   Reply With Quote
Old August 10th, 2007, 02:41 AM   #2
Depends on which resolution and data rate its at, but I'd never EVER trust a 5400 to do anything with video...I'd say its doubtfull, get a small external FW800 or esata drive to go with the book.
Jamie Allan is offline   Reply With Quote
Old August 27th, 2007, 07:49 AM   #3
HD recording ...
You should be looking at an intel laptop 2.4 CPU with 1900 X 1200 screen and internal 200 gigger , 7200 spin cycle hard drive ~ 4 gigs of ram. Add one firewire 800 200 gig external hard drive. shoot, edit or playback. That should do the trick!
Dean Harrington is offline   Reply With Quote
Old August 27th, 2007, 08:00 AM   #4
Technically an iBook might be adequate but a Macbook Pro would be preferable for several reasons. As far as hard drives are concerned, a 5400 RPM drive should be able to play a single layer of DVCProHD footage if the drive is kept defragmented and there isn't anything else bottlenecking the system. The maximum bandwidth of DVCProHD is about 12.5 MB/sec, which is well within the throughput capacity of almost any modern hard drive.
Old September 28th, 2007, 09:16 AM   #5
I haven't seen a P2 software that plays DVCPRO-HD video at full frame rate and full resolution. Panasonic software either plays video at half frame rate OR half resolution at full screen.
TingSern Wong is offline   Reply With Quote
Old September 28th, 2007, 11:31 AM   #6
I have. Quicktime Pro. FCP. DVCPRO HD is generally pretty easy for these, with a halfway recent machine.
An old iBook would have trouble with DVCPRO HD, especially a G4. A G5 iBook would probably be ok. A Macbook would work fine.
My Work: nateweaver.net
Nate Weaver is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
