"The Matchbook Mystery", a 2009 National Film Challenge short at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon EOS Full Frame for HD > EOS Full Frame Sample Clips Gallery
Post your 1D / 5D / 6D clips here... Vimeo links will automatically embed a player right in the post.
Old November 3rd, 2009, 10:16 PM   #1
Tramm Hudson Tramm Hudson is offline November 3rd, 2009, 10:16 PM
Our entry into the 2009 National Film Challenge. We had the theatrical premier at the Terrace Theater on James Island this evening.
We used two cameras, a 5D Mark II running Magic Lantern with a Canon EF 85mm f/1.2L and a stock 7D with a Canon EF 50mm f/1.4. Both cameras were in 1080p30 mode with a 1/60th shutter and typically f/1.2-f/2.0. All of the rack-focus moves were on the 5D using a Cinevate Durus follow-focus, which didn't cooperate well with the 85mm's focus-by-wire system. They mixed together well after the extensive desaturation; the color balance between the two was widely off even with identical temperature settings.
Audio was recorded on the 5D with Magic Lantern, using a juicedLink CX231 preamp and a AT875R in a Rode blimp. The in-camera gains were +0 dB analog, +12 dB digital. The 7D's audio was used as a guide track to align the clips, although there really wasn't much shot with the 7D.
Tramm Hudson
Wizard Status
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon EOS Full Frame for HD > EOS Full Frame Sample Clips Gallery
