#1 | ||||
Thanks for sharing,
a few questions how is the workflow to keep the same aperture for all the scenes? Do you always try to point the camera to the same neutral color everytime before shooting? did they use manual focus lens? Thanks |
#3 | |
However, when you get the chance to cut a trailer for it, you can bet we'd all love to see it. :)
Need to rent camera gear in Vancouver BC? Check me out at camerarentalsvancouver.com |
@Andy,
Yes, we used manual lenses. I also have a 70-300mm 4-5.6 IS in the kit. I'm not sure if they used it (we have a 200mm f/4 Nikon), but if they did, it was partially unscrewed. So, yeah, we had full control over aperture, shot everything at 1/40 (indicated), and used ISO (via the exposure compensation wheel) to optimize the overall exposure. @Dylan, We also submitted to the LA Film Festival, but probably few others. Our real goal is to launch the web series. The film festival launch is part of our promotional strategy. And we will *definitely* cut a trailer; however, first, we need to finish the final version of the film.
Jon Fairhurst |
#5 |
I just spoke to Nathan in detail about the issues with setting exposure on the shoot. Here's what he told me:
* Many times he was able to point the camera toward a light, and place it in a certain exposure zone, get what he needed, hit AE Lock, adjust the compensation and shoot. About 80% of the time it was this easy. * Night shots were easy (camera wise). The camera opens things up. You lock them. You lock and adjust the exposure. Simple. * Other times, it was a real pain - especially on a tripod. In general, he was using the on-set lights for adjusting the shutter. This is fine on the SteadyTracker, but you lose your framing if you do that on a tripod. I expected him to use a flashlight, but as the director and camera op, he already had his hands full. * I mentioned my suggestion to Canon that when you press AE Lock, it should NOT lose lock when you press STOP during video recording. Nathan responded that the AE Lock button should also be a toggle. (I agree.) You can press other buttons to stop AE Lock, but they don't make intuitive sense, and you have to move your hand to do it. Anyway, we would both prefer that AE Lock be fixed until a) you leave Live View, or b) you stop the lock by pressing AE Lock again, or the other buttons that disable it (but not when you stop recording.) * The need to set the exposure for every single take was definitely annoying. Other stuff he learned is that hats suck for lighting! There is one indoor scene where the woman was lit perfectly, but the guy had a shadow on his eyes, so they had to adjust the lights. In retrospect, the first shot should have been of the guy removing his hat, as he was indoors. The outdoor lighting we really tough because of the hat shadows. You can't really have them take the hats off outdoors. But the camera worked beautifully. Anyway, Nathan is now noodling over the trailer. And I'm going to re-do some of the music this weekend. The fun never ends!
Jon Fairhurst |
#6 |
thanks Jon, a few more questions:
You Said: "set an optimal ISO with the histogram" -did you use an ISO higher than 1000? "We always used 1/40" -Do you always play with the Aperture to archive the above? -or play with the ISO to Archive it and use a Small aperture to have a nice DOF? -Do you always shoot in Exposure Simulation to see the histogram and find optimal ISO? Hope Makes Sense, Cheers Andy |
#7 | |
We were able to keep the ISO under 1000 for all of our scenes by using a small light kit. We open with a montage of downtown scenes of a small city at night. Those might have been higher, but they look great. For exposure, we set the aperture for the artistic look we needed, which was somewhat open, but not all the way. A lot of our shots were with the 50mm lens, so unless something was very close to the camera, the DOF was moderate. We'd then offset the exposure compensation to -2, point the camera at or near a light to get to 1/40, and hit AE Lock. Once locked, we frame the shot and dial in the desired ISO, based on what we saw on the histogram. 1/40 was chosen simply because it's the only exposure that allows full control of ISO. We use it consistently, so everything matches scene to scene. We shot in "Video and Stills" mode. All the setup was in Live View with the shutter pushed part way. By pressing the Info button multiple times, we could get to the view mode we wanted. For color balance, we use an Expo Disk, shoot a photo and use that for the WB reference. We'd also shoot photos and look at the histogram to confirm the exposure. It's definitely not a one-man-under-pressure, critical-event-NOW, run-n-gun procedure. But when you're working sets, props, costumes, make up, and lights, it's fairly reasonable. Once you know your settings and have the WB set, then, for the second take, you just dial the wheel down, point at the light, lock the exposure, and dial the wheel back up to your previous setting and hit RECORD. Of course, if the camera didn't lose lock when you stop recording, it would be that little bit better, and wouldn't upset the flow on the set. The camera isn't perfect, but is by far the cheapest solution for a mostly controllable, multiple lens, variable DOF narrative project.
Jon Fairhurst |
#8 | |
thank you for all the information
Your help is much appreciated Good luck with the film looking foward for the trailer Andy Quote:
#9 |
I did not know that festival in Seattle so big.
My hobby is limos and photos. Look at Seattle town car blog. |
