50hz flicker example at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon EOS Full Frame for HD > EOS Full Frame Sample Clips Gallery
Post your 1D / 5D / 6D clips here... Vimeo links will automatically embed a player right in the post.
Old December 18th, 2008, 07:21 PM   #1
Josh Dahlberg Josh Dahlberg is offline December 18th, 2008, 07:21 PM
I took my 5d to a shopping area today to discover 50hz flicker (in signs, shop windows, reflections) splashing about everywhere.
I've posted an example on Vimeo, shot with a 24mm Nikkor @f2.8. My friend is sitting outside, but there's a chemist with 50hz lighting in the background.
My apologies for the jerky motion - I let Vimeo convert 30p>24... I should have done that myself.
Canon 5DmkII 50hz flicker on Vimeo
Josh Dahlberg
Old December 18th, 2008, 07:31 PM   #2
Try to pay attention to the shutter speed. Test it again. It should work.
Mathieu Kassovitz is offline   Reply With Quote
Old December 18th, 2008, 07:49 PM   #3
Hi Mathieu, can you elaborate? Has a solution been found for easily achieving a desirable shutter speed? I must have missed it. Thanks.
Josh Dahlberg is offline   Reply With Quote
Old December 18th, 2008, 09:32 PM   #4
You just need a multiple of the electrical system's frequency. I mean a shutter speed that can match the 50Hz frequency. 1/100th, 1/50th . . . should work fine in New Zealand.
Old December 18th, 2008, 10:10 PM   #5
Okay, but we can't effectively control shutter speed with the 5D mkII, and therein lies the problem. How does one set a shutter of 1/100th or 1/50th? In video mode, even the shutter speed info provided is often patently false, as others have noted.
Old December 18th, 2008, 10:57 PM   #6
In movie mode? Seems not. Only exposure simulation.
Take a look:
Canon 5D Mark 2 Video Aperture Manipulation Demo on Vimeo
1/100th with f/5.6 but 1/50th with the least aperture. Or . . . manual lenses control.
Old December 19th, 2008, 01:20 AM   #7
Take a look:
Hi Mathieu... thanks for the link. These tricks to get the camera behaving are all good fun and games - and useful for personal projects - but not very practical when you have a paying client and you have to repeat the steps over and over again every take.
I can't complain too much, because I knew the camera had limitations when I bought it, but I really hope Canon will make a few simple changes in a firmware update so we don't have to fool around.
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon EOS Full Frame for HD > EOS Full Frame Sample Clips Gallery
