Test | Canon 550D! at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon EOS Crop Sensor for HD > EOS Crop Sensor (APS-C) Sample Clips Gallery
Post your EOS M / 60D / 7D / Rebel clips here... Vimeo and YouTube links will automatically embed a player right in the post.
Old August 15th, 2010, 05:28 PM   #1
Test | Canon 550D!
Howard Sand Howard Sand is offline August 15th, 2010, 05:28 PM
Have been testing and played around with my new Canon 550D/T2i this week.
Here is the test edit:
Lens: 18-135mm
Editing: Sony Vegas 7
CC: Magic Bullet Looks
Song: Edward Sharpe and the Magnetic Zeros - Janglin
Howard Sand
Old August 15th, 2010, 08:09 PM   #2
Nice! Love the processing and look.
John C. Chu is offline   Reply With Quote
Old August 16th, 2010, 12:28 AM   #3
Slash Rules!
Can I ask you guys something?
Almost every video I've looked at on this board (and I've watched quite a few) using the 5D/7D/t2i has a certain "look" to it. . .this is generally characterized by desaturated colors (current video excluded) and super duper contrast, and blacks without detail.
Is that a look people are getting in post, or is this a limitation of the way the camera shoots, or is it a look folks are dialing in via menus in the cams?
This video looks really cool for the most part, but something that bothers me is that extreme contrast/ridiculous blacks.
Looking at that shot of the rocks on the water. . .the "fill" side of the rocks falls off to complete darkness in broad daylight! Totally unrealistic! Are these cams that limited in dynamic range? I thought the dynamic range was the same as if it was taking stills. Not so? Is it at least comparable to an SD miniDV camera (e.g. Canon XL2)?
JUst curious. Thanks.
Old August 16th, 2010, 07:07 AM   #4
Yes, I use a look called Magic Bullet Looks.You can download the trial here: Red Giant Software: Downloads - Trial Versions Download Form.
These looks correct the colors in the post.I may use a little too much contrast at some few shoots,I know. The reason I use much contrast is that it removes dust from shoots and make the shadows sharper.
Howard Sand is offline   Reply With Quote
Old August 16th, 2010, 05:06 PM   #5
Slash Rules!
So what kind of dynamic range is this came capable of? The only cam I have an extensive experience with lately is the old XL2. you can set it to have a pretty wide dynamic range (I don't know the number of stops, sorry), or dial in a fairly crushed setting like in these videos. So is the t2i capable of that, or better?
I just don't think I've seen a single DSLR video that didn't have that super contrasty look.
Old August 17th, 2010, 02:19 AM   #6
these cams can be adjusted for any color look you prefer,i dont bother with C/C, the only thing that slightly disapoints me is the sharpness i expected slightly more from 1920P, there is no way to compare the PQ to GLs for sure i used one the 550 is far superior, i get perfect blacks and white contrast.
Martyn Hull is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon EOS Crop Sensor for HD > EOS Crop Sensor (APS-C) Sample Clips Gallery
