Ripping video from a DVD at DVinfo.net
Old May 15th, 2007, 12:04 PM   #1
My company is celebrating their 80th year selling Caterpillar tractors this year, because of this they had the head of Caterpillar shoot a "thank you" video that they now want me to rip and put into our own 80th anniversary video.
Any ideas how I can pull the footage from the DVD? I'm guessing I'll need a special software for it. Final Cut Express can't do it right? I've never tried taking something off of a finished DVD. If you open the DVD folder it lists a couple files with .BUP, .IFO, .VOB file names but that doesn't mean anything to me. Can anybody with experience in this lend a hand? Thanks!
I'm using a Mac OS X 10.4.9 with Final Cut Express HD 3.0.
"Life is a comedy in longshot but a drama in close up." ~ Charlie Chaplin
Patrick McAvoy is offline   Reply With Quote
Old May 15th, 2007, 02:33 PM   #2
What you need is the .vob files, which are the actual video files. Some NLEs will import them as they are, for others (Premiere Pro for example) you need to change the .vob extension to .mpg and it will work fine - I am not sure if you need to do this, I am not familiar with FC or any other Mac software. Beware of the quality though... you will more than likely get compression artifacts and generally a lower quality. Best thing would be to acquire the original tape and work off of that, not the DVD.
Now, if the DVD is copy protected, then you're up for some real work, but it can be done... it's probably not the case since the DVD was done at your request.
In case you don't need any editing done on it, keep the file as it is and incorporate it into your final product - I assume that would be also a DVD. You may need to either change the extension to mpg or use MPEG Streamclip (free, availble for both Windows and OSX) to turn your .vob into a .mpg.
Ervin Farkas
www.AtlantaLegalVideo.com
Old May 15th, 2007, 09:38 PM   #3
Hi
Google vobedit it will convert the vobs back to elementary audio/video streams.
Chuck
Chuck Wall is offline   Reply With Quote
Old May 16th, 2007, 07:37 AM   #4
Thanks for the help guys, is there a Mac version of vobedit?
Old May 16th, 2007, 01:25 PM   #5
mpegstreamclip should do the trick (well the PC version does so I expect the mac version will too)
just copy the vob files over from the disc to your hard disk and have streamclip save as mpegs
DVDs are split into title sets with corresponding vob file names
eg VTS_01_0.VOB, VTS_01_1.VOB VTS_01_2.VOB VTS_01_03.VOB are all part of the same title set (eg a single 3GB program split into 1 GB chunks)
you should usually avoid any VOBs that end _0.VOB (eg VTS_01_0.VOB) as those are usually just menu information
for a DVD with several VOBs in a title set you can select them all in streamclip (ignoring the vob that ends _0.VOB) in one go and have it write out a single combined file, or you can load each individually (eg VTS_01_1.VOB) and create a seperate mpeg for each in turn.
Steven Cowie is offline   Reply With Quote
Old May 16th, 2007, 01:40 PM   #6
mpeg streamclip does the trick well on a mac, I have done it several times
www.wanah.nl
Djee Smit is offline   Reply With Quote
Old May 17th, 2007, 09:22 AM   #7
mpeg streamclip did the job! Thanks guys, couldn't have done it without you.
