burning a PAL dvd at DVinfo.net
Old May 12th, 2007, 04:47 PM   #1
burning a PAL dvd
I have an NTSC dvdsp project with all ntsc media and would like to burn a PAL dvd. what is the easiest way to do so.
thanks
andy
dvdsp 4, 2.7 dual g5.
Andrew Kemler is offline   Reply With Quote
Old May 15th, 2007, 02:42 PM   #2
Since no one attempts an answer... I am not sure about DVDSP, but in Adobe Encore you need to start the other way around: set your project properties to whatever your final product needs to be. So in your case you need to start the project as a PAL project, the software should encode (transcode?) whatever assets you use into PAL. But again, you need advice from someone who knows DVDSP.
Ervin Farkas
www.AtlantaLegalVideo.com
Old May 15th, 2007, 09:36 PM   #3
Hi
There is a software called dvfilm that will convert your ntsc source into pal. You will need to author the disc in pal with correctly sized menus.
dvfilm.com look for atlantis.
Hope this helps!
Chuck
Chuck Wall is offline   Reply
