DVD-R quality - Page 2 at DVinfo.net
Old February 23rd, 2007, 05:35 PM   #16
Well, I got lucky this time and my outdoor wedding DVD came out okay. It's just too bad I have to rely on luck so much. When I get some more professional software, like final cut studio, at least I'll have some control over compression.
Kevin, thanks for the advice, although I got it too late for this project. I did notice some pixelation on the main menu video clip (only 28 seconds long) but I decided to live with it.
I've been using a kind of strange workflow that I have little control over, but I've been happy with the results so I haven't messed with it. It goes like this:
1) Capture 1080i HDV via firewire as Apple Intermediate Codec
2) Edit the AIC video in final cut express HD
3) Export as full-quality, non-independent Quicktime file
4) Import the Quicktime file into iDVD, set up menus, and hit "burn"
And viola, I have a letterboxed NTSC DVD that plays in any DVD player. The funny thing is, it has a progressive, filmic look to it when it's all said and done. So, I'm assuming that iDVD is somehow "downconverting" my 1080i to 480i--or is it making it 480p? Or is Quicktime always automatically progressive? Does anyone understand the black magic that's happening within the bowels of my computer?
Chris Barcellos, I don't even know if my DVD's are progressive. That's what I'm trying to figure out!
Stephen Claus is offline   Reply With Quote
Old February 23rd, 2007, 06:58 PM   #17
Originally Posted by Stephen Claus
Just so happens that tonight I'll be encoding my first outdoor wedding, shot on the edge of a lake, with lots of waving trees, grass, and water. I'll be attempting to dump 79 minutes of this onto a single layer--with iDVD!!
I AM TERRIFIED!!!
Most of my weddings are shot outdoors and usually run 90 or more minutes. I limit run time to 1 hr, 45 min per disc, just to be safe. Never had a problem with iDVD so long as I used top quality media. Although the learning curve is a bit steep (was for me) DVD Studio Pro is a lot more satisfying and, once you get used to it, almost as easy as iDVD.
Prepare your DVD in iDVD slowly and carefully. Keep background music simple and short, use the least complex transitions, and you should be satisfied. A 90 min video on my G5 1.8 takes about 3 1/2 hours to encode and burn.
Waldemar
Waldemar Winkler is offline   Reply With Quote
Old February 24th, 2007, 09:31 AM   #18
Bill Davis has made great points about how the encoding will make the greatest difference. I want to add that iDVD offers has very, very limited options for encoder settings, and I don't think it can recognize the compression markers you can embed in a QuickTime file with Final Cut. iDVD should be considered a very blunt instrument for the job. If you're working on a Mac then Compressor will offer a very high level of control over your end result.
youtube.com/benhillmedia
linkedin.com/in/benhillmedia
Benjamin Hill is offline   Reply With Quote
Old February 24th, 2007, 10:48 AM   #19
I am using Ulead MovieFactory 5 for my DVDs and the results are excellent for 100 minutes video. Of course I am using good quality single layer DVDs.
Stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old February 28th, 2007, 11:30 AM   #20
The quality of the DVD media is irrelevant in regard to the compression. That would be like saying "I had a great steak at Sullivan's Steakhouse last night. Of course, I used very expensive silverwear." No matter how expensive the silverwear, it doesn't change the taste of the food.
Don't misunderstand, media quality is important for other reasons: compatibility with your burner, compatibility with the client's player, consistency of the product from disc to disc, etc. However, it won't effect the quality of the image. If you're getting a decent image, it's because you're getting good quality compression. Movie Factory is what is giving you the good image quality, not the dvd media.
This goes back to the original post at the top of this thread. The idea that DVD-R is responsible for the poor image quality. As has been explained here, that is not it, at all. I remember the first DVD I burned, and how disappointed I was that it did not look like a Hollywood disc. Since then, I have learned some lessons about compression, but I still can't make an end result that is as flawless as a HW production. But it's like everything else in Hollywood. They throw insane amounts of money at every step of the process to create something that we just can't duplicate. The compression software, hardware, and technicians that they use dwarf what many of us can do with idvd, Studio Pro and the like. And don't miss the value of those technicians. They will do painstaking hands-on work to set the compression markers and rates from scene to scene and frame to frame to get the most out of the bitrate.
Stephen, I'm pretty sure your dvd is SD 480i. That would be the default setting for your burn. You would have to tell it to do progressive. I don't know if idvd can do that, I don't use it, since I have Studio Pro. I guarantee it is not HD 1080i. There is no way to put that much HD footage on an SD dvd.
Sony PMW-EX1R, Canon XL H1, XHG1, Panasonic GH2, Mac Pro 3.2 Quad running FCPS 3, FCPX, & Adobe Creative Cloud CC www.creativejuicesvideo.com
Vence Vida is offline   Reply With Quote
Old February 28th, 2007, 01:15 PM   #21
Originally Posted by Vence Vida View Post
Don't misunderstand, media quality is important for other reasons: compatibility with your burner, compatibility with the client's player, consistency of the product from disc to disc, etc. However, it won't effect the quality of the image... etc...
Except maybe dropouts on cheap blanks...
Ervin Farkas
www.AtlantaLegalVideo.com
Old February 28th, 2007, 02:09 PM   #22
Well a dropout will only happen when your camcorder records to the tape...on the DVD you would get CRC errors...
This is more about compatibility than anything else.
90% of the time the CRC errors are due to the fact that people pick up a blank DVD and read that it is a x16 speed and they burn it at that (and skip on the verify part). I've learned by testing the slower you burn the less CRC errors and the more compatibility you will have. I go as low as I can on the burn (x4) even though my drive can burn at x18 and the disks are rated at x16. Another thing to keep in mind is that some older DVD players will choke and refuse to read anything around CBR 8,400 (I go with 8,100 to be safe)....even though max bit rate is 9,800 (video) and 10080kbps for everything (video, audio, subs)
Alex Amira is offline   Reply With Quote
Old February 28th, 2007, 02:20 PM   #23
Also, a "drop-out" or playback error is not bad image quality. The image was fine, it just didn't make it to the screen. That is a playback error, not compromised image quality due to dvd compression.
Old February 28th, 2007, 04:06 PM   #24
Originally Posted by Alessandro Machi View Post
That's not what I was talking about. It's generally wise to make a tape back up once the NLE Master is completed. I'm suggesting that if one is having trouble making a high quality DVD copy, it might be wise to first export the NLE timeline to tape via firewire (since this step might happen anyways), than reimport the tape directly to the DVD authoring program. I'm not saying to do this on every job, but it might be worth trying if one is not happy with the DVD quality prior to trying this method.
That won't change the quality of the source footage though. Dumping to tape then re-capturing is just time wasted because the footage you are re-capuring is exactly the same as the footage you dumped off to tape.
-A
Andrew Kimery is offline   Reply With Quote
Old March 1st, 2007, 08:29 AM   #25
Dropout means LOSS OF DATA regardless of the storage medium (tape, disk, card, etc). CRC refers to something related, but different: the process of DETECTING errors.
Dropout: 1. The dropping away of a flake of magnetic material from magnetic tape, leading to loss of signal. 2. A failure to properly read a binary character from data storage. This is usually caused by a defect in the storage medium or by a malfunction of the read mechanism. 3. In magnetic tape, disk, card, or drum systems, a recorded signal with an amplitude less than a predetermined percentage of a reference signal.
A cyclic redundancy check (CRC) is a type of hash function used to produce a checksum – a small, fixed number of bits – against a block of data, such as a packet of network traffic or a block of a computer file. The checksum is used to detect errors after transmission or storage. A CRC is computed and appended before transmission or storage, and verified afterwards by the recipient to confirm that no changes occurred on transit.
Source: Wikipedia.
Regards,
Ervin Farkas
Old March 1st, 2007, 12:41 PM   #26
Source: Wikipedia.
Regards,
I speak in real industry terms and the way professionals in the video industry use these terms. Dropouts most of the time are associated with tape based medium. CRC is widely used with disk based medium (hard drive platers, DVDs, CDs) etc.
You would not burn a DVD, give it to your duplication house and say "Let me know if my DVD has any dropouts".
As far as Wikipedia they just put stuff there black and white. Certain terms are used in different ways depending what industry you are in. Oh yeah...I almost forgot about Essjay, a senior member of the Wiki management team who is involved with the daily Wiki articles and changes. It seems that Essjay has been taking the Wiki concept to heart to much as he put up a lot of false info about himself in his Wiki profile (saying that he was a tenured professor with a PhD degree in theology and a degree in canon law).
SOURCE (the FORCE IS STRONG WITH THIS ONE):
Well I'm quoting straight from the NewYorker which I may add is a well known and trusted news source. I'm sure this article will be on a lot of the news outlets very soon.
LINK:
http://www.newyorker.com/fact/conten.../060731fa_fact
TheInquirer picked this up already:
http://www.theinquirer.net/default.aspx?article=37939
Best of luck and while most articles is Wikipedia are great and accurate when a top management member lies about himself it shakes my confidence and question the whole Wikipedia system.
