Export to DVD...Upper or Lower fields first? at DVinfo.net
Old October 24th, 2006, 04:13 AM   #1
I'm going to be exporting a DVD from premiere to watch on a TV. Should I use a field order of upper or lower fields first, or does that not really matter? Should I rather deinterlace/set it to progressive scan?
Aviv Hallale is offline   Reply With Quote
Old October 24th, 2006, 08:06 AM   #2
if ur source is interlaced, stick with interlaced... if its a dv source, use lower field first
hdv upper field depending on ur camera
Peter Jefferson is offline   Reply With Quote
Old October 24th, 2006, 10:09 AM   #3
What would be the difference between selecting Progressive in the field order menu and simply checking the deinterlace box in the top left of the settings? For already progressive footage, will Premiere detect this and blank out the field order/deinterlace option?
Old October 25th, 2006, 12:15 AM   #4
progressive scan within DV is seen as interlaced (as the interlace stream is the transport stream of the progresssicve frames),
In post, you use a pulldown service to remove the exceesive frames.
if its native progressive, its recomended to render as progressive, as pulldown add/removal will usually be autoamtic anyway, based on the output files requirements
