DVD Studio Pro questions? at DVinfo.net
Old October 13th, 2006, 01:12 PM   #1
Hey everybody,
- When I export my project to DVD Studio Pro and put it on dvd, I see vertical stripes in the footage when I play it on the DVD player. Anybody knows how to make the footage more smooth? Is it a compression thing maybe?
- How can I make a still image of the menu in DVD Studio Pro, because I'd like to use it on the DVD cover?
I hope someone can help me with these questions. Thanks in advance!
Niels
Niels Neeskens is offline   Reply With Quote
Old October 14th, 2006, 09:56 AM   #2
Hello,
The first problem could be a number of issues. For example, it could be interlaced artifacts from your source footage if it was shot in 480i, 1080i. In that case, you have to de-interlace your project and then compress it. If you deliver to DVD a lot, you may want to consider shooting progressive video. De-interlacing doesn't always produce the best results. Secondly, if you're using a template in DVDSP, you might try to use a screen capture utility to get a picture. Also, you can always export a frame from FCP or use Adobe Photoshop to create menus that can be repurposed for album art. Adobe Illustrator is also a great program for producing album artwork for your project.
I hope that helps,
Cale Rogers is offline   Reply With Quote
Old October 17th, 2006, 02:50 PM   #3
Thank you Cale it helped a lot!
Cheers mate
Niels
Old October 19th, 2006, 10:33 AM   #4
How do you de-interlace a project? I can't find a way to do that?
Niels
Old October 19th, 2006, 02:12 PM   #5
There are a couple of ways to attempt de-interlace. In FCP make a new sequence and change the "Field Dominance" setting to "none." The drag your finished sequence into the new sequence you made. Then apply the de-interlace filter from the effects tab to the clip in the sequence. Render or compress that out to see if it works. Remember to use a progressive compression setting (checking off settings that interpret interlaced fields). The results will vary and you may need to try a better de-interlace filter from a third party such as Nattress. But, that workflow can get you started.
Good luck,
