How do you burn a DVDSP project onto a External DVD burner? at DVinfo.net
Old December 22nd, 2005, 06:35 PM   #1
I have an Internal DVD burner that is not working, and I bought an external. How do I get the DVDSP or the OS to burn to my external, not the internal?
TIA!
Derek Lewis is offline   Reply With Quote
Old December 27th, 2005, 05:04 PM   #2
Use the Format or Build/Format command instead of Burn. DVDSP will let you choose your output device (if you had a DLT or something else attached then this would show up in the list as well). If Mac OS recognizes your external burner then it will be one of your options.
Zach Mull is offline   Reply
