XL2 25p to DVD anyone? at DVinfo.net
Old December 14th, 2005, 01:14 AM   #1
I really hope someone in PAL land can help...
I realise I'm at the fringe of an area that's been covered at length, but I still don't understand why I can't get a reasonable result with 25p footage output to a standard TV monitor from a DVD created in DVD StudioPro 3.0.2.
I've captured the 25p XL2 footage, shot with shutter speed 50, in FCP via firewire, capture settings: DV PAL 48kHz, anamorphic.
Then exported the sequence 'using compressor' from FCP. The sequence had the following sequence settings :
Field Dominance = 0
Anamorphic checked
Frame size = 720 x 576 Aspect ratio = CCIR 601/PAL (5:4)
Pixel aspect ratio = PAL CCIR 601
Field Dominance = none
Editing timebase = 25
Quicktime video settings = DV-PAL
Quality = 100%
Before exporting the sequence, I viewed it in the FCP canvas at full screen, and it looks good, minimal aliaising, but with a few artifacts on the panned shots.
I compress using the 'MPEG-2 PAL 60 minute High Quality 2 pass VBR Widescreen' pre-set in Compressor 1.2.1. When that MPEG-2 asset is imported and previewed in DVD StudioPro, it looks good when viewed on my 15" PowerBook with the DVD SP Viewer enlarged.
But when I burn to DVD, play through a JVC XV -- N33 DVD player, and view it on a standard definition PAL TV, it looks very average, similar to the footage I was seeing when I ignorantly set the FCP sequence setting Field Dominance to 'lower' for PAL 25p... full of aliasing jaggies and artifacts.
I tried customising the Compressor pre-sets, the last setting I tried was:
Description: 25p from FCP
File Extension: m2v
Video Encoder
Format: M2V
Width: 720
Height: 576
Pixel aspect ratio: 0.703
Crop: None
Frame rate: 25
Aspect ratio: 16:9
Field dominance: Auto detect
Average data rate: 7 (Mbps)
2 Pass VBR enabled
Maximum data rate: 8 (Mbps)
Better motion estimation
Closed GOP Size: 6, Structure: IP
DVD Studio Pro meta-data enabled
I wonder if later versions of Compressor allow a Field Dominance setting of 'None', as 1.2.1 only has the options: 'Upper', 'Lower' or 'Auto'.
As always it would be great if I could post a clip, but my connection crawls.
Does anyone have an answer? -- phil.
aspirant
Phil Rogerson is offline   Reply
