FCE capturing footage from DVD at DVinfo.net
Old December 1st, 2005, 06:10 PM   #1
I want to bring some DVD footage into FCE. I plan to run it out my DVD player's S video port into my pd150 then through firewire into FCE. My question is, is there some way in FCE to capture footage that has no time code? Is there a setting where I can turn off time code in FCE? Or do I need to record to tape then digitize?
Daniel Stevenson is offline   Reply With Quote
Old December 1st, 2005, 06:55 PM   #2
Don't quite know what system you are running, but why not just rip it off the disk itself? A lot of times you can take the VOB folder and copy it to your hard drive. I know FCP can open the video file. Or get yourself some DVD ripper software. Just a suggestion. Could save you some hassle.
Good Luck.
James out------
Check out the Southern Winds Film Festival. Call for entries is now open!
http://www.southernwindsfilmfestival.com
http://www.phigmentphilms.com
James Bridges is offline   Reply With Quote
Old December 1st, 2005, 10:19 PM   #3
In the capture setting select non controllable device then play your dvd and use the capture now button.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply
