DVD Studio Pro, SD, and True 16:9? at DVinfo.net
Old September 28th, 2005, 10:34 PM   #1
According to the owner's manual, DVD Studio Pro only supports true 16:9 on HD projects. For SD, the footage must be 4:3 or anamorphic 16:9. My short film was shot with an XL2, which is true 16:9. What settings will I use for making a 16:9 DVD with this software?
TIA
Javier Urena is offline   Reply With Quote
Old September 29th, 2005, 05:37 AM   #2
Javier,
Although the XL 2 shoots true 16:9, it's still anamorphic because it's fit into a 720x480 frame since all DV footage is 720x480. Actually, all SD DVDs are a frame size of 640x480 per the MPEG2 spec.
This does not matter. In DVDSP you set the frame size by selecting a track and choosing 4:3, 16:9 letterbox, or 16:9 pan and scan in the General tab of the Tracks pallette. This tells the DVD player how to display the video. Choose "16:9 Letterbox" for full screen 16:9 play back on a widescreen TV. This way it will display properly on a widescreen set and will automatically letterbox on a 4:3 set.
Dave Perry Cinematographer LLC
Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net
Dave Perry is offline   Reply With Quote
Old September 29th, 2005, 07:00 PM   #3
Thank you Dave. So I will always treat footage from an XL2 as anamorphic. Gotcha.
