is my film too short for dvd player to read? - Page 2 at DVinfo.net
Old September 9th, 2005, 11:17 PM   #16
Originally Posted by Kevin McNerney
Also, related to using Vegas, when I rendered this one, I ended up with a .mv2 file instead of mpg. What's the difference? Or maybe this is a question for the Vegas board, but I mention it here in case it has relevance to my other problem.
The .mv2 file is video only. It should be accompanied by a file with the same name and the extension .wav.
It just means the video and sound are on separated files. But it is a normal procedure.
Benjamin Durin is offline   Reply With Quote
Old September 12th, 2005, 12:38 PM   #17
Update. Well, even burning at 2x (the slowest setting) the dvd-r still won't play in my neighbor's pioneer player, even though it plays fine in every other player I've tried.
Also discovered that rendering solid black after the credits only takes a faction of the time compared to rendering video.
And I solved the temp file error by freeing up more space on C drive, though I never did find exactly where these temp file folders were.
Thanks for all the advice and tips, I think I'm starting to get the hang of dvd burning now.
Kevin McNerney is offline   Reply With Quote
Old September 14th, 2005, 05:26 AM   #18
Try looking up that Pioneer here http://www.videohelp.com/dvdplayers
Enter Pioneer and the model number or search through the results. Anything struck out means that a respondant could not get that media to work in that player. Light Grey either means not tested on inconclusive.
George Ellis is offline   Reply
