Building a DVD Duplication Tower - Have Questions. at DVinfo.net
Old August 25th, 2005, 09:22 AM   #1
I'm starting down the road of building a DVD duplicator and am trying to get educated and clear on what I need.
Currently I plan to use the Wytron DVD-3000 controller.
My first question is how the controller works with a DVD drive and/or hard drive.
With a DVD drive I assume that I'd stick the disk in to be copied, tell the controller how many copies to make and keep loading the burners until the copies are complete.
How does a hard drive work in this situation? My hope is that I'd be able to rip a DVD and store it on the hard drive so that whenever I need a copy of that particular disk I can select from the controller and make copies.
Is this correct? Could I load the duplicator hard drive with all my products and just select the one I want to copy when I need it?
Bryan McCullough is offline   Reply With Quote
Old August 25th, 2005, 02:47 PM   #2
Since this doesn't seem to be a hot topic here, I jsut went ahead and bought everything myself and we'll see what happens.
Old August 25th, 2005, 08:15 PM   #3
Moved to DVD forum from Open Discussion -- sorry for not catching this earlier.
Old September 15th, 2005, 11:30 AM   #4
How did it work out. I'm trying to figure out if 1000 bucks is worth the money, or should I try building my own.
Old October 12th, 2005, 09:17 PM   #5
Worked out great.
Send me the $1000 and I'll build you one. :D
Old October 13th, 2005, 05:10 AM   #6
Worked out great.
Thanks, I've priced mine for around 600. :}
Steven Davis is offline   Reply
