Producing DVD for NTSC and PAL - what format to shoot?
I will produce DVD-s for both NTSC and PAL countries. I cannot take the shots twice, I will have to use the same footage for both versions.
I will shoot in HD with Sony EX1r and Canon 60D and 5D MkII, Editing would be made on a Mac with FCP I wonder what would be the best camera setting for this, to make DVD production for both system fast, easy and hassle free. For the Canons I am considering 30p but I cannot do that with the EX1. What would be a good workflow for this? thanks for all suggestions
Sony XDCAM EX1r, Canon 5DMkII, Røde NTG2, Røde NT1000, Røde Stereo Videomic, Sachtler DV6 SB on Gitzo 1325V, Steadicam Merlin, Omnitracker, Hackintosh 3.5Ghz Quad 8Gb RAM |
Re: Producing DVD for NTSC and PAL - what format to shoot?
how about shooting in 24p since it's available on both PAL and NTSC DVD players.
Equal Opportunity Offender
Shoot and edit in PAL as this will give you better consistent colour as well as the filmic look that people love. (25fps PAL is practically the same as 24fps film in terms of the frame rate).
Also, standards converting from PAL to NTSC will mean that you are going from a slightly higher frame resolution downwards ... which should give you a nice image quality compared to the other way around (which would be effectively uprezzing a little). So ... shoot and edit in PAL. Output your master video file from the edit and then standards convert it. Then make your NTSC DVD master from the conversion. (And the PAL DVD master from the PAL edit export.) Andrew |
