DVDSP and External burner at DVinfo.net
Old August 10th, 2011, 12:32 PM   #1
I have a project that is 7GB and won't fit on a regular DVD. I went and bought an external burner that will burn Dual Layer DVDs. How do I get DVD SP to recognize the new burner?
Calvin Bellows
www.exposureproductions.ca
Calvin Bellows is offline   Reply With Quote
Old August 10th, 2011, 01:25 PM   #2
Re: DVDSP and External burner
Just burn the Disk Image with Toast.
Old August 10th, 2011, 01:56 PM   #3
Ended up doing that...lol The DVD didn't work right it freezes at the same point every time I play it about 20 min in. Its 2.5 hrs long
Calvin Bellows
Old August 10th, 2011, 02:27 PM   #4
What was your MAX data rate? You MAY have peaked over 8mbits which can cause a lot of DVDs to fail.
