Studio Pro won't recognize h.264 at DVinfo.net
Old July 24th, 2010, 08:50 PM   #1
Can't get compressor to work in fcp so I output to h.264, but now dsp won't recognize it? How can I handle this?
http://www.leofilms.com
Feature Film Distribution
Steve Lustgarten is offline   Reply With Quote
Old July 25th, 2010, 01:03 PM   #2
Why are you trying to bring h.264 into DVDSP? If you're trying to make an SD DVD, bring over a reference file with your Timeline's settings. If you're trying to make an HD-DVD (NOT BluRay!) on DVD, make sure you're using the correct h.264 settings.
Old July 25th, 2010, 01:11 PM   #3
Hi and thanks for your reply. I'm trying to make sd dvd. The video was shot in avchd and converted through voltaic to .mov file. the original is too large for a dvd and I was trying to export through a codec that would shrink it.
Old July 25th, 2010, 08:21 PM   #4
The only format that a DVD-Video can contain is MPEG-2.
If you can't export DIRECTLY from FCP (I'd be curious to find out why...), Export the timeline in question as a Reference Movie using Current Settings and open that file in Compressor and then choose a DVD compliant MPEG-2 setting and Submit.
Old July 25th, 2010, 08:57 PM   #5
The file is about 12gb. How do I take it direct from timeline? Compressor won't open, due to background activity not being able to function.
