DVD burner help - Page 2 at DVinfo.net
Old July 10th, 2005, 12:22 AM   #16
Slash Rules!
[16:37:54] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[16:37:54] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[16:38:09] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:38:34] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:38:49] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:38:53] ExpressUI Burn process started by user.
[16:38:53] ExpressUI Destination: _NEC DVD_RW ND-3520A
[16:38:53] ExpressUI Directory for temporary files: C:\DOCUME~1\JOSHBA~1\LOCALS~1\Temp
[16:38:53] ExpressUI ------<NeroVision Project Information>--------
[16:38:53] ExpressUI --- Project type: DVD-Video
[16:38:53] ExpressUI --- Project video options ---
[16:38:53] ExpressUI Video mode: NTSC
[16:38:53] ExpressUI Aspect ratio: 4:3
[16:38:53] ExpressUI Quality: High quality (9716 kbps)
[16:38:53] ExpressUI Resolution: 720 x 480 (CCIR-601 D1)
[16:38:53] ExpressUI Sample format: Interlaced (bottom field first)
[16:38:53] ExpressUI File type: MPEG-2
[16:38:53] ExpressUI Audio format: Automatic
[16:38:53] ExpressUI Encoding mode: High Quality (2-Pass VBR)
[16:38:53] ExpressUI --- Project space information ---
[16:38:53] ExpressUI Used disc space: 0.15 GB
[16:38:53] ExpressUI --- Project contents ---
[16:38:53] ExpressUI Number of titles: 1
[16:38:53] ExpressUI 1. Peter and I MPEG-2 default DVD NTSC template (Video Title, 0h 03m 42s)
[16:38:53] ExpressUI Audio SmartEncoding ratio: 0.0 %
[16:38:53] ExpressUI Video SmartEncoding ratio: 98.0 %
[16:38:53] ExpressUI Number of menus: 1
[16:38:53] ExpressUI - Main menu (1 page)
[16:38:53] ExpressUI --------<End of Project Information>----------
[16:38:53] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[16:38:53] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[16:38:53] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[16:38:53] DVDEngine ..Session callback registered...
[16:38:53] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[16:38:53] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[16:38:53] DVDEngine ..Application service registered...
[16:38:53] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[16:38:53] DVDEngine BEGIN: IDVDSessionBaseImpl - BeginDiscAccess
[16:38:53] DVDEngine ..Access mode=read/write
[16:38:53] DVDEngine ..Flags=0
[16:38:53] DVDEngine ..Write speed=5540 KB/s (4x)
[16:38:53] DVDEngine ..Medium type=DVD-R
[16:38:53] DVDEngine DVD format is 1
[16:38:54] DVDEngine Supported Access Modes: 0x00000001
[16:38:54] DVDEngine **BEGIN: IDVDSessionBaseImpl - Update HCB state
[16:38:54] DVDEngine **END: IDVDSessionBaseImpl - Update HCB state
[16:38:54] DVDEngine END: IDVDSessionBaseImpl - BeginDiscAccess
[16:38:54] DVDEngine BEGIN: IDVDVideoSessionImpl - Prepare
[16:38:54] DVDEngine ..BAO activated
[16:38:54] DVDEngine **BEGIN: _DVDVideo - Prepare
[16:38:54] DVDEngine ..VTS_Ns=1...
[16:38:54] DVDEngine ****BEGIN: _DVDVideoBase - Prepare VMG
[16:38:54] DVDEngine ...VMGM_VOBS_exist = true
[16:38:54] DVDEngine ******BEGIN: VMGM_VOBS - Process Create
[16:38:54] DVDEngine ********BEGIN: _VOBS - Process VOB
[16:38:54] NeroVision Analyze video stream
[16:38:54] NeroVision Seg. | frames | weight | volume
[16:38:54] NeroVision ------+---------+--------+--------
[16:38:54] NeroVision 0 | 1 | 2 | 2
[16:38:54] NeroVision total : 2
[16:38:54] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[16:38:54] DVDEngine ...Duration 333667
[16:38:54] DVDEngine ..._streamtime_frame_duration is 333667
[16:38:54] DVDEngine ...This is a still stream
[16:38:54] DVDEngine ...Stream 0 is 'Video'
[16:38:54] DVDEngine ...Stream 1 is 'System/Stream'
[16:38:54] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[16:38:54] NeroVision Estimate Size
[16:38:54] NeroVision +-------+------+--------+----------+---------
[16:38:54] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[16:38:54] NeroVision | 0 | 0 | 1 | 0.03 | 150
[16:38:54] NeroVision | 1 | 0 | 0 | 0.03 | 0
[16:38:54] NeroVision total data size : 382977 bytes
[16:38:54] NeroVision multiplexed size : 397312 bytes
[16:38:54] DVDEngine ********END: _VOBS - Process VOB
[16:38:54] DVDEngine ******END: VMGM_VOBS - Process Create
[16:38:54] DVDEngine ****END: _DVDVideoBase - Prepare VMG
[16:38:54] DVDEngine ****BEGIN: _DVDVideoBase - Prepare VTS#1
[16:38:54] DVDEngine ...VTSM_VOBS_exist = false
[16:38:54] DVDEngine ******BEGIN: VTSTT_VOBS#1 - Process Create
[16:38:54] NeroVision 0 | 6538 | 1 | 6538
[16:38:54] NeroVision 1 | 132 | 2 | 264
[16:38:54] NeroVision total : 6802
[16:38:54] DVDEngine ...Duration 2225558890
[16:38:54] DVDEngine ...Stream 1 is 'Audio'
[16:38:54] NeroVision | 0 | 0 | 0 | 218.15 | 140228
[16:38:54] NeroVision | 0 | 1 | 1 | 4.40 | 5408
[16:38:54] NeroVision | 1 | 0 | 1 | 222.56 | 5341
[16:38:54] NeroVision total data size : 154829734 bytes
[16:38:54] NeroVision multiplexed size : 160333824 bytes
[16:38:54] MMTools adding cached c:\Documents and Settings\Josh Bass\My Documents\DV Projects\DVDs\movie MPEG2s\Peter and I MPEG-2 default DVD NTSC template.mpg video/0
[16:38:57] MMTools adding c:\Documents and Settings\Josh Bass\My Documents\DV Projects\DVDs\movie MPEG2s\Peter and I MPEG-2 default DVD NTSC template.mpg audio/0
[16:38:57] MMTools --- used source filters ---
[16:38:57] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[16:38:57] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[16:38:57] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[16:38:57] MMTools file type MPEG2 - audio
[16:38:57] MMTools --------------------
[16:38:57] DVDEngine ********END: _VOBS - Process VOB
[16:38:57] DVDEngine ******END: VTSTT_VOBS#1 - Process Create
[16:38:57] DVDEngine ****END: _DVDVideoBase - Prepare VTS#1
[16:38:57] DVDEngine **END: _DVDVideo - Prepare
[16:38:57] DVDEngine ..Estimated size (overall)=153 MB
[16:38:57] DVDEngine ..Estimated duration (overall)=55 sec
[16:38:57] DVDEngine END: IDVDVideoSessionImpl - Prepare
[16:38:57] DVDEngine BEGIN: IDVDSessionBaseImpl - GetDiscCaps
[16:38:57] DVDEngine ..Caps=DSCCAP_VLMNM_UDF | DSCCAP_VLMNM_ISO9660
[16:38:57] DVDEngine END: IDVDSessionBaseImpl - GetDiscCaps
[16:38:57] DVDEngine BEGIN: IDVDSessionBaseImpl - SetLabel
[16:38:57] DVDEngine Volume name (ISO9660) = "NVE3_VRDVD"
[16:38:57] DVDEngine END: IDVDSessionBaseImpl - SetLabel
[16:38:57] DVDEngine Volume name (UDF) = "NVE3_VRDVD"
[16:38:57] DVDEngine BEGIN: IDVDVideoSessionImpl - GetDiscContent
[16:38:57] DVDEngine **BEGIN: _DVDVideo - Fill FileSystemDescContainer
[16:38:57] DVDEngine ..File: 'VIDEO_TS\VIDEO_TS.IFO' (VMGI), location={undefined}, size=12.0 KB (12,288 bytes)
[16:38:57] DVDEngine ..File: 'VIDEO_TS\VIDEO_TS.VOB' (VMGM_VOBS), location={undefined}, size=416 KB (425,984 bytes)
[16:38:57] DVDEngine ..File: 'VIDEO_TS\VIDEO_TS.BUP' (VMGI), location={undefined}, size=12.0 KB (12,288 bytes)
[16:38:57] DVDEngine ..File: 'VIDEO_TS\VTS_01_0.IFO' (VTSI), location={undefined}, size=14.0 KB (14,336 bytes)
[16:38:57] DVDEngine ..File: 'VIDEO_TS\VTS_01_1.VOB' (VTSTT_VOBS), location={undefined}, size=153 MB (160,333,824 bytes)
[16:38:57] DVDEngine ..File: 'VIDEO_TS\VTS_01_0.BUP' (VTSI), location={undefined}, size=14.0 KB (14,336 bytes)
[16:38:57] DVDEngine **END: _DVDVideo - Fill FileSystemDescContainer
[16:38:57] DVDEngine END: IDVDVideoSessionImpl - GetDiscContent
Old July 10th, 2005, 12:28 AM   #17
Slash Rules!
[16:38:58] NeroAPI Burn process started at 4x (5,540 KB/s)
[16:38:58] DVDEngine BEGIN: IDVDVideoSessionImpl - CreateDisc
[16:38:58] DVDEngine **BEGIN: _DVDVideo - Create
[16:38:58] DVDEngine ****BEGIN: Create - VMGM_VOBS
[16:38:58] DVDEngine ******BEGIN: VMGM_VOBS - Process Create
[16:38:58] DVDEngine ********BEGIN: _VOBS - Process VOB
[16:38:58] NeroVision Analyze video stream
[16:38:58] NeroVision Seg. | frames | weight | volume
[16:38:58] NeroVision ------+---------+--------+--------
[16:38:58] NeroVision 0 | 1 | 2 | 2
[16:38:58] NeroVision total : 2
[16:38:58] DVDEngine **********BEGIN: IDVDEngineManagerImpl - CreateSubpictureSource
[16:38:58] DVDEngine **********END: IDVDEngineManagerImpl - CreateSubpictureSource
[16:38:58] DVDEngine **********BEGIN: CSPU::Process()
[16:38:58] DVDEngine ...'Decoding SubPicture No.' is '0'
[16:38:58] DVDEngine ..._nLines == 480
[16:38:58] DVDEngine ...Found 'bottom half' in the bottom field at bit 6152, addr. is 769 (241)
[16:38:58] DVDEngine ...Detected 'top half' at 1, addr. is 2
[16:38:58] DVDEngine ...Detected 'bottom half' at 1, addr. is 769
[16:38:58] DVDEngine ...Lines processed: 480
[16:38:58] DVDEngine ...processed 1 packs
[16:38:58] DVDEngine **********END: CSPU::Process()
[16:38:58] DVDEngine ...New VOB 1
[16:38:58] DVDEngine ..>VOB: VOBN=1, VOB_IDN=1, SA=0, VOB_V_S_PTM=33259
[16:38:58] DVDEngine ...New CELL 1
[16:38:58] DVDEngine ....>Cell: C_IDN=1
[16:38:58] DVDEngine BTNGR1_DSP_TY == 126179806
[16:38:58] DVDEngine ....|Cell: C_IDN=1, [0;54], VOBU_Ns=1, C_PBTM=0s.12
[16:38:58] DVDEngine ..|VOB: VOBN=1, VOB_IDN=1, [0;54], C_Ns=1, VOB_V_S/E_PTM=33259/69295
[16:38:58] DVDEngine ********END: _VOBS - Process VOB
[16:38:58] DVDEngine ********BEGIN: VMGM_VOBS - INFORMATION after Create
[16:38:58] DVDEngine ----------------------------------------------------------------------------------------
[16:38:58] DVDEngine General information:
[16:38:58] DVDEngine ..size=55 (110 KB)
[16:38:58] DVDEngine ..capacity=55 (110 KB)
[16:38:58] DVDEngine ..max_capacity=524287 (1.00 GB)
[16:38:58] DVDEngine ..VOB_Ns=1
[16:38:58] DVDEngine ..C_Ns=1
[16:38:58] DVDEngine ..VOBU_Ns=1
[16:38:58] DVDEngine VOB information:
[16:38:58] DVDEngine ...VOB: VOBN=1, VOB_IDN=1, [0;54], C_Ns=1, VOB_V_S/E_PTM=33259/69295
[16:38:58] DVDEngine .....Cell: C_IDN=1, [0;54], VOBU_Ns=1, C_PBTM=0s.12
[16:38:58] DVDEngine ********END: VMGM_VOBS - INFORMATION after Create
[16:38:58] DVDEngine ******END: VMGM_VOBS - Process Create
[16:38:58] DVDEngine ******BEGIN: VMGM_VOBS - Verify
[16:38:58] DVDEngine ******END: VMGM_VOBS - Verify
[16:38:58] DVDEngine ..VMGM_VOBS: size=110 KB (112,640 bytes)
[16:38:58] DVDEngine ****END: Create - VMGM_VOBS
[16:38:58] DVDEngine ****BEGIN: Create - VTSTT_VOBS#1
[16:38:58] NeroAPI Writing file to disc failed
[16:38:58] DVDEngine _BAOContext::OpenFile(): NeroBAOOpenFile() returned 3
[16:38:58] DVDEngine 1a23-0006-7135-2121-7059-0031
[16:38:58] DVDEngine Windows XP 5.1
[16:38:58] DVDEngine IA32
[16:38:58] DVDEngine WinAspi: -
[16:38:58] DVDEngine ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 11:35:32 AM
[16:38:58] DVDEngine Nero API version: 6.6.0.8
[16:38:58] DVDEngine Using interface version: 6.6.0.4
[16:38:58] DVDEngine Installed in: C:\Program Files\Ahead\Nero\
[16:38:58] DVDEngine Application: ahead\NeroVision
[16:38:58] DVDEngine Recorder: <_NEC DVD_RW ND-3520A> Version: 1.04 - HA 0 TA 0 - 6.6.0.8
[16:38:58] DVDEngine Adapter driver: <atapi> HA 0
[16:38:58] DVDEngine Drive buffer : 2048kB
[16:38:58] DVDEngine Bus Type : default (0) -> ATAPI, detected: ATAPI
[16:38:58] DVDEngine === Scsi-Device-Map ===
[16:38:58] DVDEngine CdRomPeripheral : _NEC DVD_RW ND-3520A atapi Port 0 ID 0 DMA: On
[16:38:58] DVDEngine DiskPeripheral : WDC WD400BD-75JMC0 atapi Port 1 ID 0 DMA: On
[16:38:58] DVDEngine === CDRom-Device-Map ===
[16:38:58] DVDEngine _NEC DVD_RW ND-3520A D: CDRom0
[16:38:58] DVDEngine =======================
[16:38:58] DVDEngine AutoRun : 1
[16:38:58] DVDEngine Excluded drive IDs:
[16:38:58] DVDEngine WriteBufferSize: 83886080 (0) Byte
[16:38:58] DVDEngine ShowDrvBufStat : 0
[16:38:58] DVDEngine BUFE : 0
[16:38:58] DVDEngine Physical memory : 1014MB (1038412kB)
[16:38:58] DVDEngine Free physical memory: 571MB (585688kB)
[16:38:58] DVDEngine Memory in use : 43 %
[16:38:58] DVDEngine Uncached PFiles: 0x0
[16:38:58] DVDEngine Use Inquiry : 1
[16:38:58] DVDEngine Global Bus Type: default (0)
[16:38:58] DVDEngine Check supported media : Disabled (0)
[16:38:58] DVDEngine 8.7.2005
[16:38:58] DVDEngine NeroAPI
[16:38:58] DVDEngine 4:38:57 PM #1 Text 0 File DlgWaitCD.cpp, Line 260
[16:38:58] DVDEngine Last possible write address on media: 2298495 (510:46.45, 4489MB)
[16:38:58] DVDEngine Last address to be written: -1 ( 0:00.-1, 0MB)
[16:38:58] DVDEngine 4:38:57 PM #2 Text 0 File DlgWaitCD.cpp, Line 272
[16:38:58] DVDEngine Write in overburning mode: NO (enabled: CD)
[16:38:58] DVDEngine 4:38:57 PM #3 Text 0 File DlgWaitCD.cpp, Line 2339
[16:38:58] DVDEngine Recorder: _NEC DVD_RW ND-3520A, Media type: DVD-R
[16:38:58] DVDEngine Disc Manufacturer: CMC MA - G. AF1
[16:38:58] DVDEngine Disc Application Code: 64, Disc Physical Code: 193
[16:38:58] DVDEngine 4:38:57 PM #4 Text 0 File DlgWaitCD.cpp, Line 438
[16:38:58] DVDEngine >>> Protocol of DlgWaitCD activities: <<<
[16:38:58] DVDEngine =========================================
[16:38:58] DVDEngine 4:38:57 PM #5 Text 0 File DVDR.cpp, Line 5943
[16:38:58] DVDEngine Book Type counter: 500, Book Type selected in EEPROM, command version 2
[16:38:58] DVDEngine 4:38:57 PM #6 Text 0 File DVDR.cpp, Line 5943
[16:38:58] DVDEngine 4:38:57 PM #7 Text 0 File DVDR.cpp, Line 2216
[16:38:58] DVDEngine Recording mode: Sequential Recording Mode for Multisession
[16:38:58] DVDEngine 4:38:57 PM #8 Text 0 File Mmc.cpp, Line 21261
[16:38:58] DVDEngine Set BUFE: Buffer underrun protection -> ON
[16:38:58] DVDEngine 4:38:57 PM #9 Text 0 File DVDR.cpp, Line 2362
[16:38:58] DVDEngine Start write address at LBA 0
[16:38:58] DVDEngine DVD high compatibility mode: No
[16:38:58] DVDEngine 4:38:57 PM #10 Text 0 File Cdrdrv.cpp, Line 8430
Old July 10th, 2005, 12:30 AM   #18
Slash Rules!
[16:38:58] DVDEngine ---- DVD Structure: Physical Format Information (00h) ----
[16:38:58] DVDEngine Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
[16:38:58] DVDEngine Book Type: DVD-R (2), Part Version: 5
[16:38:58] DVDEngine Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
[16:38:58] DVDEngine Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
[16:38:58] DVDEngine Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
[16:38:58] DVDEngine Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
[16:38:58] DVDEngine End Physical Sector Number of Data Area: 26127F h
[16:38:58] DVDEngine End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
[16:38:58] DVDEngine Data in Burst Cutting Area (BCA) does not exist
[16:38:58] DVDEngine Start sector number of the current Border-Out: 2FE10 h
[16:38:58] DVDEngine Start sector number of the next Border-In: 2FFA0 h
[16:38:58] DVDEngine Media Specific [16..63]:
[16:38:58] DVDEngine 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
[16:38:58] DVDEngine 00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
[16:38:58] DVDEngine 4:38:57 PM #11 Text 0 File DVDR.cpp, Line 5943
[16:38:58] DVDEngine 4:38:57 PM #12 Text 0 File DVDR.cpp, Line 5943
[16:38:58] DVDEngine 4:38:58 PM #13 Text 0 File BurnAtOnceRecorder.cpp, Line 1005
[16:38:58] DVDEngine Estimated filesystem size: 544
[16:38:58] DVDEngine 4:38:58 PM #14 Phase 36 File APIProgress.cpp, Line 276
[16:38:58] DVDEngine Burn process started at 4x (5,540 KB/s)
[16:38:58] DVDEngine 4:38:58 PM #15 Text 0 File BurnAtOnceRecorder.cpp, Line 1686
[16:38:58] DVDEngine Buffering files started
[16:38:58] DVDEngine 4:38:58 PM #16 Text 0 File BurnAtOnceRecorder.cpp, Line 1407
[16:38:58] DVDEngine Buffering VIDEO_TS.VOB
[16:38:58] DVDEngine 4:38:58 PM #17 Text 0 File BurnAtOnceRecorder.cpp, Line 2562
[16:38:58] DVDEngine Finished buffering file VIDEO_TS.VOB of size 112640 bytes (55 sectors)
[16:38:58] DVDEngine 4:38:58 PM #18 Text 0 File BurnAtOnceRecorder.cpp, Line 2629
[16:38:58] DVDEngine Finished writing file VIDEO_TS.VOB of size 112640 bytes (55 sectors)
[16:38:58] DVDEngine 4:38:58 PM #19 Text 0 File BurnAtOnceRecorder.cpp, Line 2642
[16:38:58] DVDEngine Buffering files finished successfully
[16:38:58] DVDEngine 4:38:58 PM #20 Text 0 File BurnAtOnceRecorder.cpp, Line 675
[16:38:58] DVDEngine Reserved fragment at 0. Length: 656
[16:38:58] DVDEngine 4:38:58 PM #21 Text 0 File BurnAtOnceRecorder.cpp, Line 1869
[16:38:58] DVDEngine Reserved start fragment at 0
[16:38:58] DVDEngine 4:38:58 PM #22 SCSI -1046 File Cdrdrv.cpp, Line 1181
[16:38:58] DVDEngine SCSI Exec, HA 0, TA 0, LUN 0
[16:38:58] DVDEngine Status: 0x04 (0x01, SCSI_ERR)
[16:38:58] DVDEngine HA-Status 0x00 (0x00, OK)
[16:38:58] DVDEngine TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
[16:38:58] DVDEngine Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
[16:38:58] DVDEngine Sense Code: 0x30
[16:38:58] DVDEngine Sense Qual: 0x05
[16:38:58] DVDEngine CDB Data: 0x53 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x00
[16:38:58] DVDEngine Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
[16:38:58] DVDEngine 0x00 0x00 0x00 0x00 0x30 0x05
[16:38:58] DVDEngine 4:38:58 PM #23 Text 0 File BurnAtOnceRecorder.cpp, Line 679
[16:38:58] DVDEngine Error reserving fragment (0)
[16:38:58] DVDEngine 4:38:58 PM #24 Text 0 File BurnAtOnceRecorder.cpp, Line 3629
[16:38:58] DVDEngine Disc info:
[16:38:58] DVDEngine Partitions: 1
[16:38:58] DVDEngine #0: Start: 0, Size: 640
[16:38:58] DVDEngine 4:38:58 PM #25 Phase 179 File APIProgress.cpp, Line 276
[16:38:58] DVDEngine Writing file to disc failed
[16:38:58] DVDEngine Existing drivers:
[16:38:58] DVDEngine File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 2:07:32 PM
[16:38:58] DVDEngine File 'Drivers\CDRALW2K.SYS': Ver=7.1.0.183 , size=24832 bytes, created 9/25/2004 1:32:40 AM
[16:38:58] DVDEngine File 'Drivers\PXHELP20.SYS': Ver=2.03.16a, size=20576 bytes, created 8/2/2004 2:03:00 AM (Prassi/Veritas driver for win 2K)
[16:38:58] DVDEngine Registry Keys:
[16:38:58] DVDEngine HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
[16:38:58] DVDEngine _Xcept (): Signalling Exception: 129 NeroBAOOpenFile() returned error condition _BAOContext::OpenFile()
[16:38:58] DVDEngine ****END: Create - VTSTT_VOBS#1
[16:38:58] DVDEngine **END: _DVDVideo - Create
[16:38:58] DVDEngine ########################################################################################
[16:38:58] DVDEngine ERROR
[16:38:58] DVDEngine cause: 129 (neroapi_call_failed)
[16:38:58] DVDEngine source: NeroBAOOpenFile() returned error condition
[16:38:58] DVDEngine description: _BAOContext::OpenFile()
[16:38:58] DVDEngine **BEGIN: IDVDSessionBaseImpl - Clear
[16:38:58] DVDEngine **END: IDVDSessionBaseImpl - Clear
[16:38:58] DVDEngine END: IDVDVideoSessionImpl - CreateDisc
[16:38:58] NeroAPI Burn process failed at 4x (5,540 KB/s)
[16:38:58] DVDEngine BEGIN: IDVDSessionBaseImpl - EndDiscAccess
[16:38:58] DVDEngine ..Flags=0
[16:38:58] DVDEngine **BEGIN: _MediaAccess::Release ()
[16:38:58] DVDEngine ****BEGIN: _MediaAccess::~_MediaAccess ()
[16:38:58] DVDEngine ****END: _MediaAccess::~_MediaAccess ()
[16:38:58] DVDEngine **END: _MediaAccess::Release ()
[16:38:58] DVDEngine END: IDVDSessionBaseImpl - EndDiscAccess
[16:38:58] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[16:38:58] DVDEngine ..Session callback unregistered...
[16:38:58] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
So there it is. Hope I'm not an asshole for posting this. . .I don't expect anyone to read through every line, but I thought one of you more tech-savy types might know where to look for things, and skim it, or something. To my untrained eye, on this last post with the log, in the middle of the 16:38:58 section, is where I start seeing the words "error" and "fail" a lot.
You guys are saying maybe simply turning Norton off, disabling it, isn't enough, and it needs to be uninstalled? What about my Windows firewall, or my Linksys router? Any chance they could be interfering?
Old July 11th, 2005, 08:45 AM   #19
Well, I'll take a shot at that (don't yet know where it'll land though).
The first problem I saw was at [16:37:24] with a failed "Grab still image (AVStillSource)." 'Not sure what this means, but is Nero possibly trying to pull a framegrab of your video for a menu or something?
Next point of interest: "[16:38:53] Used disc space 0.15GB"
as well as "[16:38:57] DVDEngine ..Estimated size(overall)=153MB" and "..Estimated duration(overall)=55 sec." Is your video only a minute long, or is Nero reading it incorrectly?
Farther down I see "[16:38:58] NeroAPI Burn process failed at 4x (5,540 KB/s)," so it looks like it is using 4x speed... unsuccessfully. Since your discs are rated for 8x and your burner for 16x, can you set the speed to 8x and try again? Or maybe 1x? I realize this could be getting expensive with all of the coasters you're making.
That's what I deciphered from the log anyway. Maybe someone else will see something I missed (quite likely).
As for Norton, I don't know how much may still be active even when "disabled," so I can't offer much help there. Windows Firewall... I doubt it, but I could be wrong. Linksys router... (external via Ethernet, right?) shouldn't be a problem. Some guys keep their NLE system off of all networks, period, but I think that's just for extreme virus protection, which is very understandable. I have my system on a small home network with a dialup Internet connection through a separate firewall machine (running IPCop in case anybody wanted to know), but video is not my official job, so I'm willing to take a little bit more of a risk with my PC. Still, I don't think anything like that should be causing your burner to fail.
Other things to check: do you have DVD playback software installed? If not, some programs may be lacking an MPEG-2 decoder. This probably isn't the case, but it's worth mentioning. I think PowerDVD comes with Dell machines anyway.
Can you export your MPEG-2 files as elementary streams (separate video and audio files)? Maybe Nero would be happier with that.
Is there any way to get Nero to output a "DVD Folder" aka just create all of the VOB files and store them on the hard drive? If that is successful, try burning the resulting VIDEO_TS and AUDIO_TS folders to a data DVD (with Nero) and see what happens.
'Hope this helps! -- Jeremy
There's no way for you to know if what I'm saying is true unless you know what the truth is, and there's no way for you to know what the truth is unless there is a truth that you can know. -- Frank Peretti
Jeremy Davidson is offline   Reply With Quote
Old July 11th, 2005, 11:04 AM   #20
Slash Rules!
Thanks, Jeremy. I'll give it a try.
The movie I've been trying to burn is 3:43 long. . .don't know why it thinks it's 55 secs.
Yes, there was supposed to be a framegrab for the menu.
Norton actually seems to be catching stuff and helping me (I have Norton Internet Security, as well as just the Virus Scan), in a way that AVG never did when I used to have it. I'm kinda reluctant to just get rid of it.
Also, I don't edit for a living (at all), so I only have one computer.
Old July 13th, 2005, 03:58 PM   #21
Slash Rules!
I wanted to try doing separate streams, like you guys said. . .
I'm a little lost as to how to do that in Vegas, using the MainConcept encoder.
I guess I'd render the video as a "DVD NTSC Video Stream", and then do the audio as a .wav file?
Josh Bass is offline   Reply
