#46 |
U r right...Thanks Andrew...
Pushpa-Brisbane-Australia Dell Dimension 8400;2.8GHz, 2GB RAM, Win XP with SP3, 1TB HDD;Sony PMW EX1 VideoCamera |
#47 |
Why do you think your sales doubled? Was it because you notified people that the disks were copy protected, or was it because people bought a disk, went home to try and copy it, realized they can't and came back to buy more?
I'm just wondering because if it was the "copy protection notification" method, you could just say that without actually defacing your disks. |
#48 | |
Chris, In the past, like now, orders are placed and prepaid for "X" number of DVDs. That has normally been the end of it. This year, however, the normal number of orders were placed and then about a week later, we got more orders. Almost as many as the original number. Then, a few days later there were orders for even more.... Interesting thought about the using the note and not doing anything to the disc. I DID place a small note on the DVD cover and on each disc stating that the disc was "protected" with copy-guard. My conclusion(s) might be way off, but that's all I know to attribute to the number of extra orders. |
#49 |
The scratch method...
Taky / Tom,
I really want to try this for an annual dance recital that I do for which the sales are way off this year. Many of the parents are friends and I have reason to suspect that there may be some copying going on. I added 10 minutes of black video to the end of the show in Premiere and authored the disc in Encore with the final chapter having the 10 minutes of black after the credits. After burning, I can clearly see the band on the disc. I took a razor and made several cut marks using a magnifier to make sure I am in the band area only. Tried the "copy disc" function in Cyberlink Power2go and the "copy to disc image" in Infrarecorder. Both made flawless copies with no errors. I keep going back to the disc and beating it up more until now it has about 15 deep nicks and a 2 inch strip that has been scraped totally opaque and still no errors. I thought it might be the blu-ray drive I am using to read the disc so I tried on a different machine with a regular dvd drive using Nero and still no errors. Is there something I am not doing correctly? Thanks, Mat |
#50 |
DVD are written and read from center (with some exception for dual layer)
So , if you got a DVD that is not full, you can see where data stops, because the dye is not the same color when burned. Looks like you are scratching the empty zone of the DVD, hence no effect. you have to know too, that DVD are not hard disk, so , there is no track , sector. the laser is witing a "cloud" of bits, with some of them redundant. If you scratch a disk, there are chance that the internal error correction system can compensate for it (if relevant like video-DVD). The main difference between reading a video on a DVD and copying it as data is when wathing video, you do not really care to loose some pixels, or even a full GOP, you just want the show to go on. When copying data, you want a digital copy, meaning a bit for bit image. That is why where a DVD player could forget about some scratch, a computer reading the same disk could give up displaying some error message about CRC (cyclic redundancy check) or read error. The worst thing that can happen with scratched disk protection is that some customer could return it saying it is a defective disk (and he would be right), since DVD are not supposed to be sold with scratches. Or specifically put a disclaimer about that. |
#51 | |
I found that it only took one very small cut to do the job. 1/8th of an inch, at the most, placed at the outer edge of the black video was enough. It did not take multiple cuts to do the job. Make the small cut "across" the disc, not around the disc. I then tried to copy using DVD Shrink and Nero neither program would finish the process. The copy process went fine until the last couple of minutes and then the error message came up and stated that there was an error and the program could not copy the disc: NO COPY. Stay with it all the way through the copy process. I then played the DVD back on 5 different brands of DVD players and the marked disc played fine. |
#52 |
Thanks for the replies. I guess I was meaning could I have done something wrong in the authoring that is making this disc impervious to the error.
The show itself is 02:08:00 before I put the extra 10 minutes of black footage at the end. My original burned disc before adding the black, of course, had no visible band and since I am over the 2 hour mark there is no unused area of the disc. Could there be some issue with the bitrate or transcoding? I really am at a loss. I have totally damaged the surface of the disc over the band with the black video and I can't get any of the ripping programs to error... Any suggestions would be appreciated. Mat |
#53 | |
#54 |
If it was possible to copy protect DVD's movie studios would be in seven heaven. Programs like DVDFab will copy anything. DVD/Blu-ray protection is not possible, all the protection methods has already been cracked and anyone can do it. It's a lost cause.
#55 |
Equal Opportunity Offender
Can Tom or anyone else shoot and upload some video showing how they do their marking of the disc? This might be better than just a descriptive posting.
Andrew |
#56 |
You're waisting your valuable time
I saved all sorts of DVDs my kids scratched. If one of the programs fail, another one will work - because they use slightly different techniques. DVDFab for example will copy everything and "finalize" the copy to the point it was able to copy.
Get this: I copied one my three year old stepped on - had a half inch CRACK in it!!! Just write it off and move on! If Hollywood can't do it, you don't have the resources to do it, for sure. |
#57 |
You can play DVD that has scratches all over because DVD play back will ignore some of the errors. But for bit by bit copy, that's a different story.
LA Color Pros Blog RODE Authorized Reseller . Comer LED Camera Lights . TakyBox HTML5 Menu Generator |
#58 | |
You are 100% correct, but as several forum members mentioned in this thread earlier, I know that many, with the right programs, can copy my DVDs when I am using Taky's method. I'm not concerned about the geeks and pirates. I'm just concerened about the casual everyday users who have Nero and Shrink and the other rather simple burn programs. Since I only have Nero and Shrink, those are the only ones I could test...... |
#59 |
I agree that the casual users do not know about those tools.
#60 |
Did some experimenting last night. Shooting for an error, i scratched a bit beyond the band with the black video and all three of my programs errored. So I know for some reason, the ripping programs are ignoring scratches in the area with black video. I still keep thinking it may have something to do with how premere and encore encode the black video... Could this be this possible? I output my final project from premiere as an AVI and let encore transcode it. (It says it ended up as 8.2Mbps)
Tonight I think I will try putting an audio track at the end of the 10 minutes of black just so there is some data there... |
