Gloss DVD's Epson r200/300?
Hi
I am thinking of getting an epson R200 or R300 so I can print directly and avoid the labels. So far I am using glossy labels (wedding videography) but I am hoping for a better result. How does the printing form the epson's look comapred to a glossy label from inkjet? And is there a way to make the printable DVD's look glossy? Thank you in advance Anthony |
You can get glossy white media, but I'm pretty sure Epson's inks won't dry properly on them.
The only good glossy printed discs I've ever seen were done with full color thermal transfer printing. |
Yup. We just bought a Teac P-55 and are loving it. Best quality prints I've ever seen, even rivaling Everest II. Consistent quality, and comes out of the printer UV protected and waterproof in about two minutes. The thing is heavy as a tank and built rock solid.
...of course it was about $6,000. 8-) |
#4 | |
"How does the printing form the epson's look comapred to a glossy label from inkjet?" --> Any inkjet printed DVD's will look duller than a photo quality glossy label. "And is there a way to make the printable DVD's look glossy?" --> There is but it is triky. Applying a fine coat of varnish (like those that come in spray canisters) will do wonders to a printed DVD, but, you have to aplly it in a dust free enviornment, and that's the triky part. As a side note: Run away from labels like the plage. They WILL give you trouble. Best regards, Arnaldo |
#5 |
Thanks guys, now I even more confused:)
I am kiding, just have to decide if I ll go with print on /or label.. Thanks |
#6 |
My Epson R320 has a CD/DVD Premium Surface print setting. According to the box that pops up when I select it, it requires a CD/DVD with a higher quality print surface, which gives richer quality colors, but takes up to 24 hours to dry, depending on surface quality. I've never tried it (I'm not sure what they mean by a higher quality surface; glossy, perhaps?).
#7 |
epson print dvd
The Epson R200/300 prints a really nice quality label direct onto white ink jet printable dvd's. They are not glossy - but the flat white looks very nice.
Don't use the "glossy" selection when printing (make sure it's not checked in advanced print window). If glossy is checked it activates the epson glossy cartridge. it takes to long to dry, is not necessary, and once the glossy cartridge is empty you have to replace all the cartridges or you can't print - and the glossy cartridge is mega expensive. |
#8 |
Anthony,
The Epson 200/300 normal CD/DVD setting is incredibly sharp (2,880dpi) and gives great results. I find that the ProDisc brand of DVD blanks (got mine at Meritline) has a "pearl luster" surface that looks a little nicer to me than the flat white of other media. There is really no need to use the premium setting...it uses a LOT more ink and takes forever to dry. Hope this helps. Ken the Screen Skins guy |
#9 |
I have an r200 hooked up on my PC here at work. It does give very good results but you have to compensate for the color a lot. Mine prints with all greens super saturated. The same file printed on my Epson 2200 looks perfect with no compensation. So be sure to do a test disc before printing an important disk.
Colin
http://www.thecameralens.com An online photography gallery with techniques, resources and downloadable wallpapers http://www.optikvervelabs.com Home of virtualPhotographer. A photoshop plug-in for one click photographic effects. |
