Can i use two burners with Encore? at DVinfo.net
Old November 11th, 2009, 08:44 AM   #1
i have an external dvd burner attached to the computer, can i somehow use both DVD burners when burning dvd projects from encore?
Brian MacKenzie is offline   Reply With Quote
Old November 11th, 2009, 11:32 AM   #2
What you can do is, use Encore to export to either ISO or Folder. Then use ImgBurn (free utility) to burn to DVD/BD. Encore is flaky anyway. I have been doing that to burn two DVDs at the same time launching two ImgBurn.
ImgBurn is a great utility. Ditching the bloated Nero long time ago
LA Color Pros Blog
Old November 11th, 2009, 11:57 AM   #3
excellent idea!
Old November 11th, 2009, 11:58 AM   #4
ImgBurn is great. It will remind you if your DVD folder structure is wrong, or prompt you to pick the split point if you burn dual layer DVD.
For Bluray, I export to ISO in Encore, then use ImgBurn to burn the image. Works 100%.
LA Color Pros Blog
Taky Cheung is offline   Reply
