Photoshop template for DVD printable - Epson R200
I am currently using a photoshop template but it is not 100% accurate so I have to let it 'bleed' over the edges and then wipe some excess ink off. It is so annoying. Does anyone have an accurate photoshop template for the Epson R200.
Thomas |
Have you tried converting your psd to a bmp and importing that into the Epson "Print CD" app? You'd have control there of scaling and exact position on the disk.
David Hurdon |
Here's a Photoshop CD/DVD template Epson made for the Stylus Photo 960, but I use it for the R320 and it works just fine: http://www.videohelp.com/forum/image...to960cdtem.zip.
Last edited by Christopher Lefchik; May 7th, 2005 at 11:58 AM. Reason: Clarification |
I would think that you could modify your picture etc, with text and flatten it to a PSD file and then import. Just import your PSD into the "Epson Print CD" part of the Epson 200. It then has the inner and outer ring adjustments, print.
Hope that helps. Mike
Chapter one, line one. The BH. |
