help with dvd at DVinfo.net
Old February 3rd, 2005, 11:23 AM   #1
help with dvd
Hi
I hope that someone out there can help me, iam having a bit of trouble with burning dvd's, i use pinnacle liquid 6 and also nero 6, every thing goes fine in liquid 6 until it comes to burning with verbatim dvd -r blank disc's i get a message saying that the disc in the burner is not correct or the disc is full put another disc in, when i use Philips dvd +R it works fine!.
This is also the problem in Nero 6 it will copy the Philips dvd+ R on to a Philips +R, but if i put a Verbatim - R to copy onto it won't copy these are all new disc's, I have some more dvd -R re-writeable disc's and they work fine, All this worked fine the last time i used it? any ideas.
Ian Thomas.
Thomas Video Productions
Ian Thomas is offline   Reply With Quote
Old February 3rd, 2005, 03:50 PM   #2
yes its me again,
just run a test in nero and found that some of the new verbatim dvd's were faulty! 3 in a pack of 10 others ok, just thought i would let you know.
Ian Thomas.
Old February 11th, 2005, 06:16 PM   #3
Just to let you know, Verbatim's are regarded as one of the best DVD brands avaiilable, along with Fuji (Taiyo Yuden) and Maxell.
Some DVD player's just have problems burning some brands, so this might be the problem, or the luck of an exceptionally bad Verbatim batch.
MB
Moe Belli is offline   Reply
