FX1 to DVD downconvert at DVinfo.net
Old January 16th, 2005, 02:22 PM   #1
Hello !
I tried a downconvert from 1080i upper field first to 480i lower firld first in Vegas so I can transfer it to DVD. The Vegas result was kind of blurry. So I tried it in Shake and I got a much better result.
I wish Vegas had a better resizing filter.
http://home.comcast.net/~chalbers/compare_short.mov
Right click to download
Notice the difference in the tree foliage and grass.
Frank
Frank Aalbers is offline   Reply With Quote
Old January 16th, 2005, 04:22 PM   #2
Yeah, Shake is noticably sharper. Same field order settings on both exports eh?
Jack McCann is offline   Reply With Quote
Old January 16th, 2005, 04:42 PM   #3
<<<-- Originally posted by Jack McCann : Yeah, Shake is noticably sharper. Same field order settings on both exports eh? -->>>
Yep ! Both upper field first to lower field first.
Old January 17th, 2005, 09:26 PM   #4
cool. Good to know.
Hayden Rivers is offline   Reply With Quote
Old January 19th, 2005, 12:06 AM   #5
But this quality is only visible on DVD if you also create high quality mpeg for DVD. I use 2 pass and variable rate to max 9800
Gives the best result for not much bigger file.
Frank
Old January 20th, 2005, 05:37 PM   #6
Isn't shake for Mac only?
I'm asking since you are comparing Vegas (pc only) vs Shake that I believe is Mac only. You probably run on two platforms that is pretty strange for a MAC guy. Do you know of a good resizing program for Windows?
Gabriele
Gabriele Sartori is offline   Reply With Quote
Old January 20th, 2005, 10:51 PM   #7
Re: Isn't shake for Mac only?
<<<-- Originally posted by Gabriele Sartori : I'm asking since you are comparing Vegas (pc only) vs Shake that I believe is Mac only. You probably run on two platforms that is pretty strange for a MAC guy. Do you know of a good resizing program for Windows?
Gabriele -->>>
Not really ! Shake is also on PC
The older version that is. That's what I used
Old January 21st, 2005, 01:35 AM   #8
"Not really ! Shake is also on PC"
That is why I put the question mark on my title, I knew it was for MAC but this answer is a good piece of information. I never put too much attention on it. How do you like it?
I've a 4P Opteron monster machine and I like the maximum quality since I've has much computation power as money can buy on a single machine .
Old January 21st, 2005, 01:37 AM   #9
Again on shake, I don't see windows platform, can you explain?
http://www.videomaker.com/scripts/news.cfm?id=928
thanks
Gabriele
Old January 21st, 2005, 01:06 PM   #10
Re: Again on shake, I don't see windows platform, can you explain?
<<<-- Originally posted by Gabriele Sartori : http://www.videomaker.com/scripts/news.cfm?id=928
thanks
Gabriele -->>>
As I explained before . It's an older shake version available for PC.
Shake was also on PC before Apple got a hold of it.
Frank
Old January 21st, 2005, 01:15 PM   #11
I understand now
I understand. Too bad is not on windows anymore. It is very expensive though, are you happy with it? I saw Aplle still sell an X86 version for Linux. I hate dual boot but I could do that in case.
Old January 23rd, 2005, 08:36 PM   #12
Frank:
I downloaded your QuickTime clip, and compared it to the same footage downconverted to standard defination in Vegas 5 and my downconversion looks *much better* than yours.
I'm not sure how you did your downconvert in Vegas, since your result appears to take the 16:9 HDV frame at 1440x1080 pixels an convert it to standard definition 4:3 frame at 720x480 pixels using a stretch, which distorts the picture. You'd have to go out of your way in Vegas to do that! By default, it would letterbox the 16:9 into the 4:3 frame. Even if you were targeting widescreen SD (1.2121 pixel aspect), Vegas would still create small black bars on the sides since widescreen SD is slightly wider than 16:9 if it's 720 pixels wide.
So, exactly what settings in Vegas did you use to create this?
///d@
Sony Media Software
Dennis Adams is offline   Reply With Quote
Old January 26th, 2005, 01:58 AM   #13
Just selecting the DV Widescreen template and setting quality to best.
Anything else I should do ?
Frank
Old January 27th, 2005, 08:46 AM   #14
And then how'd you get it in QuickTime format? Another format conversion? I still can't figure out why the frame is compressed (anamorphic) and doesn't have black bars on the sides. There's obviously some conversions happening *after* the Vegas downconvert.
///d@
