What is the best quality DVD to AVI encoder out there
I am looking for the best DVD to AVI encoder I can find. I know there are some out there like "dvd-to-avi", sorenson squeeze, and the like, but I have no idea which will give me the best quality results, as well as controls over the encoding functions (i.e. 2 pass, etc.) Please feel free to chime in one and all.
RED Code Chef
I think you are mixing things up. Most AVI codecs do not have
multiple pass. Do you want to get from your movie ([DV] AVI) to a DVD or do you want to rip a DVD to an AVI? It sounds like the latter but it feels like the former. From AVI to DVD the best encoders in my mind are: 1. Canopus ProCoder 2. Cinemacraft Encoder (CCE) 3. TMPGEnc 4. MainConcept (ie Vegas / Premiere) Or if you want to go from DVD to AVI the program DVD2AVI as you mentioned is pretty good. It normally encodes to xvid or divx with an AC3 or mpeg1 layer 2 audio stream. You will need these codecs installed to have those options. You can get it all from the Gordian Knot Codec Pack
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
Rob, thanks for the heads up. I am also looking for a good ac3 codec. If you know of any that are free or inexpensive I would be much obliged.
Thanks |
RED Code Chef
I don't think there are free AC3 codec out there (since royalty
must be payed if I remember correctly). However, Sony Vegas comes with one (Edward: only with Vegas + DVDA or also on the standalone?) and I believe Premiere Pro does as well. A lot of authoring applications can compress WAV/PCM to AC3 as well. But if you rip a DVD the DVD2AVI program (for example) should just copy the AC3 track that is already there to your AVI.
#5 |
Well, I only ask because I have heard that there are a few that are freeware out there. As for DVD, my primary concern now is learning how to build one from the ground up. A task I used to farm out. Which means getting to know the different components and codecs a little better.
#6 |
RED Code Chef
You still haven't said what you are trying to do exactly. Go from
AVI to DVD or the other way around. It is still a bit confusing I think. I haven't seen any freeware AC3 encoders, there are some decoders indeed (freeware, like lame).
