DVD menu/navigation at DVinfo.net
Old July 15th, 2004, 08:00 PM   #1
DVD menu/navigation
Hello,
I've just bought a g4 and have started using fcp4. Having great fun! However, I want to create a dvd with an interactive plot. The planned movie plays and pauses at a point where the dvd software gives you two or three choices, based on your choice the correct chapter plays next, and so on. I've been told that dvstudio or something would be able to put this feature on a dvd.
Any comments on this would be appreciated!
Mark Robbins is offline   Reply With Quote
Old July 21st, 2004, 04:26 AM   #2
I think I'm going to buy DVD Studio Pro for this.
Has anyone used DVD Studio Pro to make an interactive story? If so, are there any issues I should know about?
Old July 23rd, 2004, 09:03 AM   #3
Not sure if there are things you need to know about but dvdsp can handle the project.
Jake
Jake Russell is offline   Reply With Quote
Old August 2nd, 2004, 09:00 AM   #4
RED Code Chef
I think what you are trying to do is possible. Like this:
1. menu
2. movie 1
3. menu
4. movie 2
5. menu
etc.
If DVDSP allows you to go to a DIFFERENT menu AFTER a movie
is finished you are all set.
Just think of splicing your movie up into multiple parts and putting
menu's inbetween them. So it is not one big movie with pauses
in it.
It might even work with one big movie and chapter points. The
DVD spec probably allows to jump to a menu when the movie
reaches a certain chapter point and a certain register is NOT
set correctly. The menu would then set the register and jump
back to the chapter point.
That would be a more complicated approach since you would
have to do some actual programming instead of just linking. Not
sure whether DVDSP supports such things at that level either,
but the spec probably does.
I hope these ideas will point you into the right direction. Good luck!
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
