DVDs on a PC at DVinfo.net
Old March 2nd, 2004, 06:58 PM   #1
DVDs on a PC
I burned some files for a client onto DVDs in Toast 5.2 on a Mac and they cannot read them. I believe that they only have PCs in their shop. I was under the impression that any computer with a DVD-rom drive could read them. Does anyone know if there are cross platform issues with DVDs in Toast?
I'm pretty sure that I checked them before I sent them out and that they read fine on my computer, so I don't think it was an issue with the disks(at least not when they left the studio).
Cannon Pearson is offline   Reply With Quote
Old March 2nd, 2004, 07:11 PM   #2
Most PC DVD-ROM drives can read DVD-Rs and fewer DVD+Rs.
Which did you burn? If you passed your clients DVD-RW or DVD+RWs, the compatibility drops even lower. While I've had
good experiences with my DVD-Rs, I've received some from commercial sources that do not work on DVD-ROM drives, or at least, need several insertions and about five minutes to startup.
One such case was attributable to a finger smudge on the disk.
Overall, I believe that the DVD-R problems were due to low quality.
Which brand of writable DVD do you use? Also, did you test your
burned disk?
Gints Klimanis is offline   Reply With Quote
Old March 2nd, 2004, 07:49 PM   #3
The discs were DVD-Rs from a reputable name(Maxell maybe, but I'm not sure).
I vaguely remember testing the burned discs. I usually put the burned discs back in the drive and try and open a couple of files.
This client is the first one that could not read the discs. They asked me if I burned them on a Mac, which led me to believe that they are totally PC. Neither one of them worked at all. I've had individual files get corrupted before, but I've never had two discs be totally unreadable.
Old March 2nd, 2004, 08:33 PM   #4
If you are using Maxell's, there should be no issue with the media. Are you sure they have a DVD player in their sets? They may also have a much older DVD that does not support anything but DVD-ROM. Does your DVD play in a settop player?
George Ellis is offline   Reply With Quote
Old March 2nd, 2004, 08:48 PM   #5
They weren't video dvds. They were burned as data files to be read on their computers.
Old March 2nd, 2004, 09:11 PM   #6
XP natively supports DVD data disc. All other Windows OSs need something like WinDVD or other DVD software loaded (although, I did not test W2K after SP2 for this). It may be that they are using an older OS or you may not have finalized the 'burn'. Otherwise, it could be their readers.
Old March 2nd, 2004, 09:33 PM   #7
I can't believe that a design agency wouldn't have some way to read these discs. Tomorrow I'm burning them ten CDs to replace them.
Thanks for the replies.
Old March 3rd, 2004, 10:49 PM   #8
Go back to Toast and choose from the tabs on top "DATA"from the menu then choose to the left "UDF". This will allow for the reading of the DVD.
If this does not work then choose from Advanced ISO9660 as this works every time for PC computers.
Sharon Fraats is offline   Reply With Quote
Old March 13th, 2004, 01:36 AM   #9
The world is windows.
Jack Xiong is offline   Reply
