Burning 24p in DVD Architect at DVinfo.net
Old April 13th, 2009, 11:04 PM   #1
Hi THERE!
In DVD Architect 5.0, I'm burning a 24p film rendered as an mpeg2; when I go to burn the DVD I click "optimize" to set the proper framerate. In the framerate selection window the only option is 29.97
I rendered it out as a 24p mpeg yet the only available frame rate option is 29.97 and I don't know why this is. Is it even possible? Does it have to be burned at 30p because of TV resolution?
I am hoping someone can direct me in the proper procedure to burn this project in 24 frames per second.
I am using trial versions of both Sony Vegas 8.0 and DVD Architect 5.0
Any help would be greatly appreciated and put to good use.
Thank you.
Evan B. Peters is offline   Reply
