authoring questions (ac3, bitrate)
I have already read not to use a bitrate over 8000 since
the surfaces of consumer DVDs aren't reflective enough, but since I am having the DVD-R glass mastered, could I not use the highest possible bitrate, since the final would be on a regular mastered DVD? (The movie is only 15 minutes long) Would that work without the skipping/focusing problems? Also, would I be safe in using a single ac3 track? If the viewer only has 2.0 stereo, then they hear just those two channels, and if they are using 5.1, then they hear all channels ? Does this make sense? I know pros use two separate tracks, but I have no idea how to lay something like this out in my mastering software (Vegas+DVD)....as far as the ability to switch between tracks. Thanks for your help! ,Frank |
Yes you can max out the datarate if you are getting it pressed. Replicate from DLT if you can. If not use a dvd-r(A), or give the rep house a HD and see if they will author. If not then dvd-r(G) it is. Yes you can use a single AC3 stream but the 'pro' 5.1 mixes are done so they downmix to 2.0 if played on a stereo setup.
Jake |
RED Code Chef
All system that support dolby digital playback should be able
to downconvert it to stereo. But I can't imagine this isn't possible in Vegas as well. What happens if you just save it as a stereo WAV/PCM/AC3 file? I would be a bit reluctant to go to the maximum on bitrate. I don't think I've ever seen a DVD that actually pushes the maximum boundary. Yes it should work, but I wouldn't tempt faith like that. A lot of people have very cheap players with the cheapest components available.
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
Man I've loads of dvd's that are 10 Mbps CBR. Matter of fact I've got Gangs of NY on right now and it is.
The main problem as far as replication goes is if you have a spike at a layer switch then that can cause issues but other than that you can raise it up. It's one of the advantages of going to replication, Jake |
#5 |
RED Code Chef
Okay Jake. I'll keep an better eye on that bitrate meter on my
DVD player when playing those movies. I've probably been wrong about that then.
#6 |
Not wrong as many do use VBR as you'd expect but there also quite afew who use quite a high CBR datarate,
Jake |
#7 |
Jake: What's the difference between dvd-r(a) and dvd-r(g)?
Sorry for sounding ignorant - I am brand new to DVD authoring. :-) A lot of mastering houses work from DLT, but the one I am considering using (TripleDisc - Fredricksburg, VA), says that they are now only taking dvd-r, and they say a lot of people are doing that now because the extra expenses of going from DLT don't outweigh the quality. This make sense to you guys? I guess I may stay safe and keep it at 8, since I have done tests on that and it looks fine. Would just a 8 Mbps CBR be sufficient? I wouldn't have to use VBR, would I? (The short is around 15 minutes, btw.) Thanks a lot for all the help! ,Frank |
#8 |
Well dvd-r(A) is authoring media and you need an authoring drive to write it, dvd-r(G) is general media which is the 'normal' media.
www.dvddemystified.com/dvdfaq.html 4.3.2 I think for more on both of those. Wow thats just amazing. Everytime I hear of a rep house that says that I just can't beleive it. It's only the 3rd time but I just hope it's a sales person that says it and not a tech guy or they aren't the rep house and outsource the job..... "the quality." We'll it isn't so much quality(depending on how you define quality), it's a compatibility issue really. And when a rep house advises against the 'standard' then is just strange to me.... Make sure you send more than one dvd-r, but that said it doesn't sound like that rep house would run it through any major tests if it wants dvd-r over DLT. Well it's kinda down to you CBR or VBR. I'm not sure what control over VBR you have with your encoder. If you can set the max and min bitrate then you could run it through a 2-pass VBR encode. It's only 15 mins so shouldn't take too long and you can compare how things look with the various settings, Jake |
#9 |
weird when i had some stuff replicated for a festival recently... i just plugged in my external HD and gave them the image of the dvd...
they took it from there... never even put it on dvd before they pressed it :-/ zac |
#10 |
Yep thats not a bad way of doing it at all. When writing to dvd-r errors can creep in, along with scratches and so on so HD or DLT is a good way. Plus you can have copy protection, Region encoding etc when using the DLT or HD method. One reason I'd say that DLT is 'better' is that some houses will charge an authoring charge when going from a HD,
Jake |
#11 |
Thanks for answering my question!
Also, thanks for that link. I will go there in a few minutes. Jake: I was talking to a sales person. I am using the mpeg2 encoder that comes with Vegas 4.0 ('Main Concept', I believe it's called, or either it's the company's name.) The following may be answered after I review that link you posted, but I'll go ahead and ask: What would you suggest as far as the VBR min/max rates as a guideline, and what about all the other params such as 'i-frames' (I think)... ..is this similar to keyframes? And any other parameters I should know about. I am new to mpeg2 in general. Have only messed with AVIs. Thanks! ,Frank |
#12 |
RED Code Chef
If I were you I would pick a DVD template (and leave I frame
allocation and other parameters alone) and only change quality/ bitrate levels. I personally use for VBR with CCE 0 - 5000 - 8000.
#13 |
Rob: Thanks for that recommendation! The encoder has some
defaults, one being for DVD encoding. I'll just use that and adjust the bitrate like you suggest. Thanks! |
