Need help with a clip that is not showing 16:9 after DVD burn. at DVinfo.net
Old November 29th, 2003, 06:54 PM   #1
Guest
Posts: n/a
Need help with a clip I am importing. It was filmed on a PD150 with 16:9 settings from there it was imported into a Windows computer using Adobe Premiere 6.0 where it was edited 720 x 480 without 16:9 or widescreen settings at all. Then it was exported to a DVCAM tape which then I imported it into a Mac running OS X using FCP 4 here are the settings:
Frame Size: 720 x 480 Pixels
Editing Timebase: 29.97 fps
Field Dominance: Lower (Even)
Pixel Aspect Ratio: NTSC - CCIR 601 / DV
Anamorphic 16:9: On
Video Processing: YUV allowed (8-bit)
White Point: White
Compressor: DV/DVCPRO - NTSC
Millions of Colors (24 bit)
No Data Rate Limit
No Keyframes Set
Quality: 100
From there I exported out in QuickTime Pro compression as an MPEG2 to which then I imported into DVD SP 2 where all the setting are set to 16:9 letterbox not Pan & Scan.
Problem is the DVD comes out on my DVD player as 4:3 on the Mac it looks widescreen.
All ideas are appreciated (except to sell the Mac and get a PC)
Old November 29th, 2003, 07:38 PM   #2
Guest
Posts: n/a
Part 2
I tried on the computers DVD Player and it works, then on my wait for this my daughters PlayStation and it works great. Now on to the one I paid good money for a Pioneer DVD Player it looks like 4:3.
Could the Pioneer have gone belly up… as it will not play a VCD or a CD so this could be the culprit.
Old November 29th, 2003, 09:01 PM   #3
This may be something you've already done, but on your DVD player there should be a system menu item where you identify the type of TV it's plugged into. Choose either 4:3 or 16:9, depending on what type of TV you have. Otherwise you can experience the sort of problem you describe. For example, with a 4:3 TV set if you set the DVD player for 16:9 the anamorphic image will fill the screen and appear too tall and skinny. But if you set the player for 4:3 it should automatically letterbox your 16:9 video.
