Is CBR the way to go for DVDs less than 60 minutes? at DVinfo.net
Old December 11th, 2008, 06:45 PM   #1
Images: 32
Any thoughts on this? Does CBR make the most sense?
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old December 12th, 2008, 10:12 AM   #2
Depends on the bitrate. If you use max, it makes no difference.
Ervin Farkas
www.AtlantaLegalVideo.com
Old December 12th, 2008, 07:53 PM   #3
Only if you can max the bit rate. If not, any really fast scene/contrast/any other image changes could overrun a lower bit rate and hurt quality.
I generally use VBR-1 pass to handle any spikes in the data rate. If I see anything untoward, I'll run it again with 2 pass.
Old December 14th, 2008, 05:47 PM   #4
For videos 60 minutes and under I just set it to CBR 1-pass 6300kbps and forget it. Footage looks beautiful...no issues with crossfades/whatnot.
Adam Reuter is offline   Reply With Quote
Old July 26th, 2009, 03:46 AM   #5
Ive found my best pictures, including crossfades, animation effects and such comes with a two pass render.
Essentially its 8mbps max, 6mbps min and average, two pass.
I was doing a CBR, and found image degredation in the effects, such as a title fading in/out, but fine on general vision.
The biggest secret was to render the whole project to an .avi file first, THEN render that new one to MPEG2.
Doing that saves time. Doing the two pass render keeps the quality.
Ben
Ben Longden is offline   Reply
