Interlacing Artifacts and DVD at DVinfo.net
Old August 27th, 2003, 11:09 AM   #1
Hi,
If I want to write my sons wedding video to a DVD that will be played back on PC. I have interlacing artifacts when I edit. Would it be necessary to de-interlace?
Cheers
Andrew
PAL XL-1, DV Raptor, Premiere
TOTAL AMATEUR - DOING IT FOR THE FUN
Andrew Leigh is offline   Reply With Quote
Old August 28th, 2003, 04:41 AM   #2
TMPGEnc-deinterlace-double
I haven't tried this with DVD yet but for MPEG-1 on CD I recently discovered a great setting in TMPGEnc, and it is available for MPEG-2 as well. One of the set up screens provides a list of processing options that includes "deinterlace". I believe the default is "none". If you click on that you get a long series of choices, including "double". I tried it on the assumption that it might create 60 frames progressive output. I don't know for a fact that that is what actually occurs but the resulting file is beautiful when played on a PC. Not a hint of the unmatched horizontal lines that reveal interlaced footage. You might try a short clip to see if this is the result you want.
David Hurdon
David Hurdon is offline   Reply With Quote
Old August 29th, 2003, 10:55 PM   #3
Thanks David,
will attempt it this wekend.
Cheers
Andrew
Old August 30th, 2003, 09:40 AM   #4
Andrew,
Most, if not all, PC DVD players deinterlace automatically, or actually display interlaced footage. Either way, you shouldn't have to worry about the interlacing ever. Before you try anything, try making a DVD folder on your hard drive and playing it with your PC DVD player - it should play fine.
Peter Moore is offline   Reply With Quote
Old August 30th, 2003, 01:40 PM   #5
will do so first. Probably on Sunday.
Cheers
Andrew
Old August 31st, 2003, 02:06 PM   #6
You can have an issue about field order though. De-interlacing at playback time won't fix it because it matches up fields from two different frames.
See if you can set the proper field order in your conversion program if interlace is a problem.
Mike Rehmus
Old September 7th, 2003, 12:04 AM   #7
Hi
Thanks for the input guys.
Cheers
Andrew
