DVD + and - RW at DVinfo.net
Old October 24th, 2008, 02:49 PM   #1
DVD + and - RW
I am trying to figure out
1. What is the difference between DVD + and DVD - R . I always heard to buy - because more players could play them.
2. What kind of DVD RW should I get for testing my videos on DVD without having to waste DVDs?
Cinematography Site
Nathan Quattrini is offline   Reply With Quote
Old October 24th, 2008, 03:20 PM   #2
If you really want to know the difference between + and - formats go here:
DVD+R - Wikipedia, the free encyclopedia
DVD-R - Wikipedia, the free encyclopedia
Consensus is that -R is still the more compatible of the two formats. That's all I use.
As for the right RW you should use, the answer is whatever works on your gear. RW (+ and -) are both less compatible than either of the R formats. You may have a little trial and error ahead.
Here's something you might want to consider. The R media I use burns at 16X. The RW media I just checked from Staples.com only burns at 4X with one only 2X. Is your time worth the $.20 cost for burning a coaster? I've never used RW and I'll throw away one DVD for about every other project I do. It's generally for the review copy where I find something I need to change in the project.
Tripp Woelfel is offline   Reply
