Why is it a bit "red" after outputting to a DVD at DVinfo.net
Old March 26th, 2008, 06:09 AM   #1
Hi all,
I realized that the clip that I see in FCP is not that same as the clip that i see in the final SD DVD made from DVD SP 4.
I am using a canon XHA1 to record my clips. the clips are in HDV (mpeg). They are then edited in FCP 5 and later compression to SD 10bit with compressor.
I load them up to DVD Studio Pro 4 and make a SD DVD . Somehow when I look at the SD DVD on a normal TV. every thing looks a bit soft and the face of all my actors are alittle red in colour.
Can someone tell me what I did wrong?
Thank you in advance
Website: http://www.Motiononcanvas.com Camera Operator/ Video Editor in Singapore.
https://new.cinematographer.org.au/m...713/david-chia
David Chia is offline   Reply With Quote
Old March 26th, 2008, 08:58 AM   #2
Originally Posted by David Chia View Post
Hi all,
There are a lot of picture settings on your tv that could be a factor. Tint and sharpness for example. Does it look red on your computer?
Also check your video export from fcp and compressor see where the problem starts exactly.
Aric Mannion is offline   Reply
